6 Replies Latest reply on Jul 3, 2007 2:34 AM by Newsgroup_User
    Ideas for form field
    szymas
      I would like to know if anyone has an idea or has seen this:
      We have a form with a multi-select field on it, with over 1200 categories in this select box in which you can select up to ten items to search on.
      Example:
      wire
      wire dies
      wire dies - Carbon
      wire dies - Plastic
      wire dies - Steel
      wire dies - Other
      wire rope
      What I would like to do is this: have some kind of "visual" tiered system that would allow them to drill into the categories with multple items
      Example
      wire
      wire dies -- ALL
      Carbon
      Plastic
      Steel
      Other
      wire rope
      This would make the selection area shorter and cleaner.
      Any ideas?
      thanks
        • 1. Re: Ideas for
          Level 7
          You might try this:
          http://javascript.internet.com/navigation/connected-dropdown-box.html
          Walt
          "szymas" <cszymaszek@wirenet.org> wrote in message
          news:f6b4gj$iui$1@forums.macromedia.com...
          > in
          > Example:
          > wire
          > wire dies
          > wire dies - Carbon
          > wire dies - Plastic
          > wire dies - Steel
          > wire dies - Other
          > wire rope
          > that
          > Example
          > wire
          > wire dies -- ALL
          > Carbon
          > Plastic
          > Steel
          > Other
          > wire rope
          > Any ideas?
          > thanks
          • 2. Ideas for form field
            szymas Level 1
            I'm sure I can cohearse coldfusion to work within this script, but if I want ten items to search on that means I would need 10 select boxes. Maybe I should go alittle futher ;-)
            Flash-based collection recepticle that you can drag and drop items to search for into it??
            btw, thanks I'll give that one a try, but I guess i'm looking for something to simplify the page so there would not be so many dropdowns
            • 3. Re: Ideas for
              Level 7
              What you are describing does not exist in ordinary HTML. You would need to
              use some custom javascript, and I have not seen any such scripting posted or
              even mentioned here.
              Murray --- ICQ 71997575
              Adobe Community Expert
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.dreamweavermx-templates.com - Template Triage!
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
              news:f6b60c$kom$1@forums.macromedia.com...
              > want
              > ten items to search on that meanbs I would need 10 select boxes. Maybe I
              > should
              > search
              > for into it??
              > something to
              • 4. Re: Ideas for
                Level 7
                >>if I want ten items to search on that meanbs I would need 10 select boxes.
                I don't think so. Sounds like you either didn't explain what you want or you
                didn't study the function of the script I pointed to.
                Walt
                > want
                > should
                > search
                > for into it??
                > something to
                • 5. Re: Ideas for
                  szymas Level 1
                  Sorry, i guess I did not explain well enough.. this item really requires flash I beleive. To restate..
                  I want a person to be able to select up to 10 items out list that could possibly be 1200 items long. and then to submit to the query. But I do not want multiple drop-downs to clog upt he page. So my idea was to have a select an item, it will drop or be dragged into a "bucket" until they have either reached their 10 selections or their desired criteria. These items might have up to 10 sub-criterias.. like:
                  Car (All)
                  Car -- > Engine (All)
                  Car -- > Engine --> Bolts
                  Car -- > Engine --> Manifold
                  Car -- > Engine --> AC Unit
                  Car -- > Engine --> Wiring
                  Car -- > Engine --> Spark Plugs
                  Car -- > Tires
                  ..etc..
                  They may select a complete group Car -- > Engine
                  as one selection
                  or take parts of the engine they want
                  as three of their criteria
                  hope this help in the understanding..
                  I have seen flash shopping carts done this way for items added to the cart, but figured maybe it could be done for a search instead..
                  • 6. Re: Ideas for
                    Level 7
                    maybe you would give to user such combinations dropdown list?( which
                    sort your data with select statement you specify behind scenes)
                    Because you're not "all with all" combination - so there is not so much
                    "dust on the field"?
                    just an idea...
                    > Car (All)
                    > Car -- > Tires
                    > ..etc..
                    > as one selection
