5 Replies Latest reply on Feb 7, 2007 2:11 PM by breez11
    ease function not  triggered, trace triggered
    breez11 Level 1
      Here is my code Everything loads and I get the traces Hey, Buddy when I execute my code but doEase() does not trigger. If you give me an email I will be glad to send a zip of all the test files.
        • 1. Re: ease function not  triggered, trace triggered
          Level 7
          Hi!
          You are calling doEase as if doEase exists inside some MC you've just
          created with targetpath container_mc.widget1_mc. If you do a trace of that
          function before you call it, you will see that there is no doEase function
          defined in there:
          trace(container_mc.widget1_mc.doEase);
          If you change your call to something like this, then I think it should work:
          doEase(container_mc.widget1_mc);
          /Jensen/
          "breez11" <webforumsuser@macromedia.com> wrote in message
          news:epu3l3$ne1$1@forums.macromedia.com...
          > will
          > this.createEmptyMovieClip("container_mc", this.getNextHighestDepth());
          > Movieclip.prototype.oldLoadMovie = Movieclip.prototype.loadMovie;
          > Movieclip.prototype.loadMovie = function(url, vars) {
          > if (this.onData != undefined && this.onData != null) {
          > this._parent.createEmptyMovieClip("__fixEvents", 7777);
          > this._parent.__fixEvents.theTarget = this;
          > this._parent.__fixEvents.onData = this.onData;
          > if (this.onLoad != undefined && this.onLoad != null) {
          > this._parent.__fixEvents.onLoad = this.onLoad;
          > this._parent.__fixEvents.onEnterFrame = function() {
          > this.oldv = this.v;
          > this.v = this.theTarget.getBytesLoaded();
          > if (this.v != this.oldv) {
          > this.onData.call(this.theTarget);
          > if (this.v == this.theTarget.getBytesTotal()) {
          > this.theTarget.onData = this.onData;
          > if (this.onLoad != undefined) {
          > this.theTarget.onLoad = this.onLoad;
          > this.onLoad.call(this.theTarget);
          > this.removeMovieClip();
          > this.oldLoadMovie(url, vars);
          > var easing = 0.2;
          > var targX = -10;
          > var targY = 250;
          > namesArray = new Array("bg", "widget1", "widget2", "widget3", "MainLogo",
          > "MainMessage");
          > locationsArray = new Array([0, 0], [-500, 250], [275, 225], [445, 250],
          > [530,
          > 105], [410, 23]);
          > for (var i = 0; i<namesArray.length; i++) {
          > //create a clip on the root using a reference
          > container_mc.createEmptyMovieClip(namesArray +"_mc", i);
          > container_mc[namesArray
          +"_mc"]._x = locationsArray [0];
          +"_mc"]._y = locationsArray [1];
          +"_mc"].onLoad = function(){
          > trace ("Buddy");
          > container_mc.widget1_mc.doEase();
          > container_mc[namesArray +"_mc"].onData = function(){
          > trace ("Hey");
          > if (i == 0) {
          +"_mc"].loadMovie("images/"+namesArray +".jpg");
          > } else {
          +"_mc"].loadMovie("images/"+namesArray +".swf");
          > function doEase(target) {
          > target.onEnterFrame = ease;
          > function ease() {
          > var dx = targX-this._x;
          > var dy = targY-this._y;
          > if (Math.abs(dx)<=1) {
          > this._x = targX;
          > this._y = targY;
          > delete this.onEnterFrame;
          > trace("done");
          > } else {
          > var vx = dx*easing;
          > var vy = dy*easing;
          > this._x += vx;
          > this._y += vy;
          > var myXML_xml = new XML();
          > myXML_xml.ignoreWhite = true;
          > myXML_xml.onLoad = myFunction;
          > myXML_xml.load("xml/links.xml");
          > function myFunction() {
          > for (i=1; i<=4; i++) {
          > _root["link"+i] = myXML_xml.firstChild.childNodes[i-1];
          > //trace(_root["link"+i].firstChild);
          +"_mc"].onPress = function() {
          > getURL(_root["link"+this.id].firstChild, "_parent");
          • 2. Re: ease function not  triggered, trace triggered
            Peter Lorent Level 2
            I send you the .fla I was using (version 8) on your request. If you have the upgrade to 8 your problem is solved. Otherwise, well let us know.
            • 3. Re: ease function not  triggered, trace triggered
              Jensen: no that won't work because he still isn't waiting for the jpg/swf's to load.
              • 4. Re: ease function not  triggered, trace triggered
                The whole principle of preloading in MX can be confusing. That's why they introduced MovieClipLoader in MX2004.
                Well, if you want that code to run in MX you just need a simple function to preload the data and THEN call a function to perform an action on the fully loaded clip. Try attached code.
                • 5. Re: ease function not  triggered, trace triggered
                  breez11 Level 1
                  Freakin Awesome. Thanks alot. Now I have another issue. I need targx & targy to be different values for nameArray items 1-3.
                  here is the updated code
