0 Replies Latest reply on Feb 6, 2007 9:16 AM by Jeff_Hight
    Replace component value with a variable
    Jeff_Hight
      I'm not sure where to begin so I can explain this clearly. I am working with a pre-built form component that allows you to add a number of variables to an array, then by dragging a component to the stage and naming it the same thing, it will pass all of these values to a php page. Rather than using a component, I would like to be able to use a custom button instead. The only way I've found that I can do this is by dragging a TextInput component off the stage and giving it the proper name and then setting the text of this component via the button click. Is there a cleaner way to do this?
