4 Replies Latest reply on Mar 26, 2015 9:07 AM by Chuck Uebele
    merge all layers
    roychen
      if have layer1 and layer2 and layer3,backgroud is white,i want to Merge all layers to background.all layers is cmyk.
      because layer is cmyk(0<=c,m,y,k<=100), below in black(k), Compare the color data of  the different layer, in the same coordinate position,for example ,
      A.layer1---c1 m1 y1 k1,layer2---c2 m2 y2 k2,layer1 and layer2 Merge to layer1
      B.layer1---c1 m1 y1 k1,layer3---c3 m3 y3 k3,layer1 and layer3 Merge to layer1
      C.layer1 and background  multiply
      D.finish
      Merge arithmetic :
      if k1>=k2  k1=k1+k2-2*k1*k2/100+k1*k1*k2/10000
      else k1<k2 k1=k1+k2-2*k1*k2/100+k1*k2*k2/10000
      Can edit by JavaScript? pls help me....thx
        • 1. Re: merge all layers
          roychen Level 1
          //file format is cmyk
          //run this javascript  must close all show layer!!!!!
          //file is have 3 layer,name is  layer1 and layer2 and background
          //all Results display on layer1
          var units = app.preferences.rulerUnits;
          app.preferences.rulerUnits = Units.PIXELS; // set ruler units to PIXELS
          var myDocument = activeDocument;
          var theWidth = myDocument.width;
          var theHeight = myDocument.height;
          for(var i=0; i<theWidth; i++){
              for(var j=0; j<theHeight; j++){
          selectlayer2();//select layer2
          showlayer();//=======show layer
          // =============================================build selection
          var id84 = charIDToTypeID( "setd" );
              var desc13 = new ActionDescriptor();
              var id85 = charIDToTypeID( "null" );
                  var ref7 = new ActionReference();
                  var id86 = charIDToTypeID( "Chnl" );
                  var id87 = charIDToTypeID( "fsel" );
                  ref7.putProperty( id86, id87 );
              desc13.putReference( id85, ref7 );
              var id88 = charIDToTypeID( "T   " );
                  var desc14 = new ActionDescriptor();
                  var id89 = charIDToTypeID( "Top " );
                  var id90 = charIDToTypeID( "#Pxl" );
                  desc14.putUnitDouble( id89, id90, 0.000000+j );
                  var id91 = charIDToTypeID( "Left" );
                  var id92 = charIDToTypeID( "#Pxl" );
                  desc14.putUnitDouble( id91, id92, 0.000000+i );
                  var id93 = charIDToTypeID( "Btom" );
                  var id94 = charIDToTypeID( "#Pxl" );
                  desc14.putUnitDouble( id93, id94, 1.000000+j );
                  var id95 = charIDToTypeID( "Rght" );
                  var id96 = charIDToTypeID( "#Pxl" );
                  desc14.putUnitDouble( id95, id96, 1.000000+i );
              var id97 = charIDToTypeID( "Rctn" );
              desc13.putObject( id88, id97, desc14 );
          executeAction( id84, desc13, DialogModes.NO );
          // ===========================================choose  colorSamplerTool
          var idslct = charIDToTypeID( "slct" );
              var desc1249 = new ActionDescriptor();
              var idnull = charIDToTypeID( "null" );
                  var ref1133 = new ActionReference();
                  var idcolorSamplerTool = stringIDToTypeID( "colorSamplerTool" );
                  ref1133.putClass( idcolorSamplerTool );
              desc1249.putReference( idnull, ref1133 );
              var iddontRecord = stringIDToTypeID( "dontRecord" );
              desc1249.putBoolean( iddontRecord, true );
              var idforceNotify = stringIDToTypeID( "forceNotify" );
              desc1249.putBoolean( idforceNotify, true );
          executeAction( idslct, desc1249, DialogModes.NO );
          //=========================================click colorSamplerTool
          var idMk = charIDToTypeID( "Mk  " );
              var desc1016 = new ActionDescriptor();
                  var ref954 = new ActionReference();
                  var idClSm = charIDToTypeID( "ClSm" );
                  ref954.putClass( idClSm );
              desc1016.putReference( idnull, ref954 );
              var idPstn = charIDToTypeID( "Pstn" );
                  var desc1017 = new ActionDescriptor();
                  var idHrzn = charIDToTypeID( "Hrzn" );
                  var idPxl = charIDToTypeID( "#Pxl" );
                  desc1017.putUnitDouble( idHrzn, idPxl, 0.500000+i );
                  var idVrtc = charIDToTypeID( "Vrtc" );
                  desc1017.putUnitDouble( idVrtc, idPxl, 0.500000+j );
              var idPnt = charIDToTypeID( "Pnt " );
              desc1016.putObject( idPstn, idPnt, desc1017 );
          executeAction( idMk, desc1016, DialogModes.NO );
          //=================================get current layer2 samplecolor data(cmyk)
          var doc = app.activeDocument,
          samps1 = doc.colorSamplers;
          for ( var X = 0; X < samps1.length; X++ ) {
               var C2= Math.round( samps1[X].color.cmyk.cyan ),
               M2 = Math.round( samps1[X].color.cmyk.magenta ),
               Y2 = Math.round( samps1[X].color.cmyk.yellow ),
               B2= Math.round( samps1[X].color.cmyk.black );
          //==========================close show layer2
          var idHd = charIDToTypeID( "Hd  " );
              var desc66 = new ActionDescriptor();
                  var list15 = new ActionList();
                      var ref49 = new ActionReference();
                      var idLyr = charIDToTypeID( "Lyr " );
                      var idOrdn = charIDToTypeID( "Ordn" );
                      var idTrgt = charIDToTypeID( "Trgt" );
                      ref49.putEnumerated( idLyr, idOrdn, idTrgt );
                  list15.putReference( ref49 );
              desc66.putList( idnull, list15 );
          executeAction( idHd, desc66, DialogModes.NO );
          // =======================------------------------select layer1
              var desc67 = new ActionDescriptor();
                  var ref50 = new ActionReference();
                  ref50.putName( idLyr, "layer1" );
              desc67.putReference( idnull, ref50 );
              var idMkVs = charIDToTypeID( "MkVs" );
              desc67.putBoolean( idMkVs, false );
          executeAction( idslct, desc67, DialogModes.NO );
          // ========================================Show layer1
          var idShw = charIDToTypeID( "Shw " );
              var desc68 = new ActionDescriptor();
                  var list16 = new ActionList();
                      var ref51 = new ActionReference();
                      ref51.putEnumerated( idLyr, idOrdn, idTrgt );
                  list16.putReference( ref51 );
              desc68.putList( idnull, list16 );
          executeAction( idShw, desc68, DialogModes.NO );
          //======================================get current layer1 samplecolor data(cmyk)
          samps = doc.colorSamplers;
          for ( var Q = 0; Q < samps.length; Q++ ) {
               var C1 = Math.round( samps[Q].color.cmyk.cyan ),
               M1 = Math.round( samps[Q].color.cmyk.magenta ),
               Y1 = Math.round( samps[Q].color.cmyk.yellow ),
               B1= Math.round( samps[Q].color.cmyk.black );
          // ======================================del samplecolor point
          var idDlt = charIDToTypeID( "Dlt " );
              var desc1284 = new ActionDescriptor();
                  var ref1157 = new ActionReference();
                  var idAl = charIDToTypeID( "Al  " );
                  ref1157.putEnumerated( idClSm, idOrdn, idAl );
              desc1284.putReference( idnull, ref1157 );
          executeAction( idDlt, desc1284, DialogModes.NO );
          //==============================Obtained  C3,M3,Y3,B3 color data by calculation
          var C3,M3,Y3,B3;
          if(C1>=C2)  {
              C3=C1+C2-2*C1*C2/100+C1*C1*C2/10000;
          else  {
              C3=C1+C2-2*C1*C2/100+C1*C2*C2/10000;
          if(M1>=M2)  {
              M3=M1+M2-2*M1*M2/100+M1*M1*M2/10000;
          else  {
              M3=M1+M2-2*M1*M2/100+M1*M2*M2/10000;
          if(Y1>=Y2)  {
              Y3=Y1+Y2-2*Y1*Y2/100+Y1*Y1*Y2/10000;
          else  {
              Y3=Y1+Y2-2*Y1*Y2/100+Y1*Y2*Y2/10000;
          if(B1>=B2)  {
              B3=B1+B2-2*B1*B2/100+B1*B1*B2/10000;
          else  {
              B3=B1+B2-2*B1*B2/100+B1*B2*B2/10000;
          fillcolor();
          //======================================select layer2
          function selectlayer2(){
              var desc64 = new ActionDescriptor();
                  var ref47 = new ActionReference();
                  ref47.putName( idLyr, "layer2" );
              desc64.putReference( idnull, ref47 );
              desc64.putBoolean( idMkVs, false );
          executeAction( idslct, desc64, DialogModes.NO );
          //====================================display(show) layer
          function showlayer(){
              var desc65 = new ActionDescriptor();
                  var list14 = new ActionList();
                      var ref48 = new ActionReference();
                      ref48.putEnumerated( idLyr, idOrdn, idTrgt );
                  list14.putReference( ref48 );
              desc65.putList( idnull, list14 );
          executeAction( idShw, desc65, DialogModes.NO );
          //======================================fill color to layer1
          function fillcolor(){
          var idFl = charIDToTypeID( "Fl  " );
              var desc197 = new ActionDescriptor();
              var idUsng = charIDToTypeID( "Usng" );
              var idFlCn = charIDToTypeID( "FlCn" );
              var idClr = charIDToTypeID( "Clr " );
              desc197.putEnumerated( idUsng, idFlCn, idClr );
                  var desc198 = new ActionDescriptor();
                  var idCyn = charIDToTypeID( "Cyn " );
                  desc198.putDouble( idCyn, C3 );
                  var idMgnt = charIDToTypeID( "Mgnt" );
                  desc198.putDouble( idMgnt, M3 );
                  var idYlw = charIDToTypeID( "Ylw " );
                  desc198.putDouble( idYlw, Y3 );
                  var idBlck = charIDToTypeID( "Blck" );
                  desc198.putDouble( idBlck, B3 );
              var idCMYC = charIDToTypeID( "CMYC" );
              desc197.putObject( idClr, idCMYC, desc198 );
              var idOpct = charIDToTypeID( "Opct" );
              var idPrc = charIDToTypeID( "#Prc" );
              desc197.putUnitDouble( idOpct, idPrc, 100.000000 );
              var idMd = charIDToTypeID( "Md  " );
              var idBlnM = charIDToTypeID( "BlnM" );
              var idNrml = charIDToTypeID( "Nrml" );
              desc197.putEnumerated( idMd, idBlnM, idNrml );
          executeAction( idFl, desc197, DialogModes.NO );
          run speed very very very very very very very very very very very very very  slow
          How to modify the increase speed?
          pls help me
          • 2. Re: merge all layers
            Chuck Uebele Adobe Community Professional & MVP
            Using the color sampler tool is VERY SLOW!!! And it looks like you're sampling every pixel. I can imagine this would take hours to run. I not sure, but I don't think there is a better option while using javascript, Some other programing language such as C++ would be needed.
            • 3. Re: merge all layers
              roychen Level 1
              C++--- I did not learn this programming language。
              pls help me
              thx
              • 4. Re: merge all layers
                I don't know C++ either. I have done some scripts using the sampling tool, and it is very slow.
