1 Reply Latest reply on Mar 21, 2015 10:48 AM by Imposturous
    Index our of Range Error
    Imposturous
      Hello I am getting:  Script Error:  Index Out of Range for the following
                 sprite(spriteNumber).member = member(pBoard[cardNumber],"Cards")
      This is for a Cast:Cards where I have 10 cast members.  I have a matrix of 20 cards in a memory game and the cast members have to half the matrix number.  But I can't get over this error that won't go away no matter how hard I try.
      The whole script which is placed on the frame reads:
      -- Settable Properties
      property pSpriteOffset, pDisplayDelay, pGameOverFrame
      property pClickSound, pMatchSound, pNoMatchSound
      property pNumberOfCards -- number of cards in the game
      property pBoard -- holds a list of what cards are where
      property pCard1 -- the first card in a pair clicked on
      property pCard2 -- the second card in a pair clicked on
      property pCardTimer -- the time that the second card was clicked
      on getPropertyDescriptionList me
        list = [:]
        -- pSpriteOffset is used to determine how far from
        -- the top of the Score the first card is
        -- so, if the first card starts in channel 11,
        -- the offset would be 10 (10 away from channel 1).
        addProp list, #pSpriteOffset,\
          [#comment: "Card Sprite Offset",\
           #format: #integer,\
           #default: 0]
        -- pDisplayDelay is how many ticks the pair of
        -- cards will be kept on the screen for the player
        -- to see before they are removed or turned back over
        addProp list, #pDisplayDelay, \
          [#comment: "Display Delay",\
           #format: #integer,\
           #default: 60,\
           #range: [#min: 0, #max: 240]]
        -- when a sprite is clicked, what sound is played?
        addProp list, #pClickSound,\
          [#comment: "Click Sound",\
           #format: #sound,\
           #default: "click sound"]
        -- when a sprite is matched, what sound is played?
        addProp list, #pMatchSound,\
          [#comment: "Match Sound",\
           #format: #sound,\
           #default: "match sound"]
        -- when a sprite is not matched, what sound is played?
        addProp list, #pNoMatchSound,\
          [#comment: "No Match Sound",\
           #format: #string,\
           #default: ""]
        -- when all sprites are matched, which frame should the movie go to?
        addProp list, #pGameOverFrame,\
          [#comment: "Game Over Frame",\
           #format: #marker,\
           #default: #end]
        return list
      end
      -- shuffles the cards to build the pBoard list
      -- initializes the game properties
      on beginSprite me
        -- refers to the "Cards" cast library to see how many cards there are
        pNumberOfCards = the number of members of castLib "Cards"
        -- build a list with each card in the list twice
        list = []
        repeat with i = 1 to pNumberOfCards
          add list, i
          add list, i
        end repeat
        -- fill the pBoard list up randomly with items from
        -- the previously created list
        pBoard = []
        repeat while list.count > 0
          r = random(list.count)
          add pBoard, list[r]
          deleteAt list, r
        end repeat
        -- initialize the game properties
        pCard1 = 0
        pCard2 = 0
      end
      -- called by the sprites when the user clicks
      -- the spriteNumber parameter is the sprite number clicked
      on turnCard me, spriteNumber
        -- play sound, if there is one
        if pClickSound <> "" then puppetSound 1, pClickSound
        -- determine the card number
        cardNumber = spriteNumber - pSpriteOffset
        if pCard1 = 0 then -- first card clicked
          -- record this card
          pCard1 = cardNumber
          -- turn it over
        else if pCard2 = 0 then -- second card clicked
          -- ignore if it is the same card
          if cardNumber = pCard1 then exit
          -- record this card
          pCard2 = cardNumber
          -- turn it over
          -- set the timer
          pCardTimer = the ticks
        else -- two cards are already turned over{6}
          -- this happens if the user clicks very quickly
          -- force a look at the two cards
          returnCards(me)
          -- make sure the card was not clicked on twice
          if sprite(spriteNumber).memberNum = 0 then exit
          -- record new card as the first card
          pCard1 = cardNumber
          -- turn it over
        end if
      end
      -- looks at the two cards turned over and compares them
      on returnCards me
        if pBoard[pCard1] = pBoard[pCard2] then -- they are a match
          if pMatchSound <> "" then puppetSound 2, pMatchSound
          -- remove both sprites{8}
          sprite(pCard1+pSpriteOffset).memberNum = 0
          sprite(pCard2+pSpriteOffset).memberNum = 0
          -- check for game over
          if checkAllMatched(me) then
            go to frame pGameOverFrame
          end if
        else -- no match
          if pNoMatchSound <> "" then puppetSound 2, pNoMatchSound
          -- turn both cards back{7}
          sprite(pCard1+pSpriteOffset).member = member("Card Back")
          sprite(pCard2+pSpriteOffset).member = member("Card Back")
        end if
        -- reset the game properties
        pCard1 = 0
        pCard2 = 0
      end
      on exitFrame me
        if pCard1 <> 0 and pCard2 <> 0 then -- two cards are turned
          if the ticks > pCardTimer + pDisplayDelay then -- time has expired
            -- check the cards to see if there is a match
            returnCards(me)
          end if
        end if
        -- loop on the frame
      _movie.go(_movie.frame)
      end
      -- check to see if the game is over
      on checkAllMatched me
        -- loop through all cards
          -- determine the card's sprite
          spriteNumber = i + pSpriteOffset
          -- if it is still a card, then the game is not over
          if sprite(i).memberNum <> 0 then return FALSE
        end repeat
        -- all cards missing, so game over
        return TRUE
      end
      and this is the script that is placed on the sprite in the matrix:
      on mouseUp me
        -- simply tell the frame script that this sprite was clicked
        sendSprite(0,#turnCard,me.spriteNum)
      end
        • 1. Re: Index our of Range Error
          Imposturous Level 1
          Well I'm just letting anyone who is reading know that I finally solved my own problem after much thought I and looking at the code over and over.
          This is what I did:
          Here I noticed that there is code to add a list twice
            list = []
              add list, i
              add list, i
            end repeat
          so I thought, what I'm getting is only one part of this list on my matrix and I finally got a bright idea that somewhere in this code there is another list to add.  So I looked carefully and finally assumed that:
            pBoard = []
              add pBoard, list[r]
              deleteAt list, r
            end repeat
          the above has
          add pBoard,list[r]
          in the code once so maybe I need to add another
          Therefore I ended up with:
            pBoard = []
              add pBoard, list[r]
               add pBoard, list[r]
              deleteAt list, r
            end repeat
          which solved my error and now the game is working.  What a relief!!
