0 返信 最新の回答 日時: Mar 20, 2015 11:29 PM ユーザー:natashab51803024
    driving directions using voice research.
    natashab51803024 Level 1
      The homescreen has five screen  systems from by the addition of  information  shortcuts shortcuts, widgets and versions  which you are able to  modify . Wallpaper Creator is also supported by the telephone . Within  the content  shortcut choices , your choices are photographs , notes  or favorites . You can  keep  case about  the displays  using  the help  of tiny dot in the bottom, which slides according to  the quantity  of screens  you are  opening . Nevertheless, while there are  five systems you'll find only four dots . The notification  bar  at the very  top allows entry to  activities  fresh e-mails , such as  calls, communications, etc. Wallpaper Creator - Android Apps on Google Play
