4 Replies Latest reply on Mar 26, 2015 1:20 PM by beh_gras_beh
    XML from CharacterStyles
    beh_gras_beh Level 1
      Dear Indesign users,
      There is an script in this forum to add XML from ParagraphStyles.
      Is this possible with CharacterStyles?
      Greetings from Holland
        • 1. Re: XML from CharacterStyles
          Loic.Aigon Adobe Community Professional
          If your script can do it with ParagraphStyle, it will be certainly feasible with characterStyles. Have you a link towards the script code ?
          Loic
          http://www.ozalto.com
          • 2. Re: XML from CharacterStyles
            Well,
            I got this so far, but its's definitely not working at all.
            #target indesign
            myDoc = app.activeDocument;
            myPageItems = myDoc.allPageItems;
            xmlRoot = myDoc.xmlElements.item("Root");
              createXML();
              function createXML() {
              for(var i=0; i<=myPageItems.length; i++) {
              var myTextFrame = myPageItems[i];
              if(myTextFrame instanceof TextFrame){
              var myCharacters = myTextFrame.characters;
              for(var j=0; j<myCharacters.length; j++) {
              // Debug
              alert("Item: "+ myPageItems[i] +"\n"
                                            + "Characters: "+ myCharacters.length +"\n"
                                            + "CharacterStyle: "+ myCharacters[j].appliedCharacterStyle.name +"\n"
                                            + "Text: "+ myCharacters[j].contents +"\n"
                                            + "parent: "+ myCharacters[j].parent +"\n"
                                            // EndDebug
              myCharacters[i].select();
              selection = app.selection[0];
            if(myCharacters[j].appliedCharacterStyle.name == "TAG-01"){ xmlRoot.xmlElements.add({markupTag:"TAG-01", xmlContent:selection}); myCharacters[j].parent.markup( xmlRoot.xmlElements.add({markupTag:"TAG-01"}) );}
            else if(myCharacters[j].appliedCharacterStyle.name == "TAG-02") xmlRoot.xmlElements.add({markupTag:"TAG-02", xmlContent:selection});
            Thank you very much for the help.
            • 3. Re: XML from CharacterStyles
              You should consider using mapStylesTOXMLTag…
              var tag = function(tagName) {
                var doc, st, tg;
                //Exit if no documents open
                if ( !app.documents.length ) return;
                //Referencing the doc
                doc = app.activeDocument;
                //Referencing the style
                st = doc.characterStyles.item ( tagName );
                !st.isValid && st  = doc.characterStyles.add ({name:tagName} );
                //Referencing the tag
                tg = doc.xmlTags.item (tagName );
                !tg.isValid && tg = doc.xmlTags.add({name:tagName});
                //Creating links between styles and xml tags as a xmlExportMap
                em = doc.xmlExportMaps.add(st, tg);
                //Apply Tag to styles
                doc.mapStylesToXMLTags();
              tag("TAG-01");
              HTH
              Loïc
              • 4. Re: XML from CharacterStyles
                Stupid me..... Got it working....
                /* XML maken */
                #target indesign
                createXML();
                                              var myParagraphs = myTextFrame.paragraphs;
                                              for(var j=0; j<myParagraphs.length; j++) {
                                                        // Debug
        + "Paragraphs: "+ myParagraphs.length +"\n"
        + "ParagraphStyle: "+ myParagraphs[j].appliedParagraphStyle.name +"\n"
        + "Text: "+ myParagraphs[j].contents +"\n"
        + "parent: "+ myParagraphs[j].parent +"\n"
                                                        // EndDebug
                                                        myParagraphs[j].select();
                if(myParagraphs[j].appliedCharacterStyle.name == "TAG-01"){ xmlRoot.xmlElements.add({markupTag:"TAG-01", xmlContent:selection}); myParagraphs[j].parent.markup( xmlRoot.xmlElements.add({markupTag:"TAG-01"}) );} else if(myParagraphs[j].appliedCharacterStyle.name == "TAG-02") xmlRoot.xmlElements.add({markupTag:"TAG-02", xmlContent:selection});
