I am trying to install both Flash Builder (FB) 4.7 and ColdFusion Builder (CFB) 3 into the same IDE and cannot seem to be able to do so successfully. The environment is Mac OSX Yosemite.I have tried installing CFB as a plugin into FB (can't, FB uses Eclipse 4.3), FB as a plugin into CFB (succeeds but FB does not show up as a perspective even though it seems to install successfully), and each as a plugin into Eclipse stand-alone 4.2.2 (last one installed does not show up). Now, my "uninstall" for CFB is hosed - hangs at 32% - i think some original paths written to the uninstall directories are no longer there or something.
Is there a trick to getting FB and CFB 3 to work together on Mac Yosemite?
The only thing you actually need, is the .link file from the Dropins folder. If you have FB plugin already running in 3.7 or 4.2 - simply copy 'fb-4_7-plugin-encoded.link' into the Dropins folder of your eclipse Kepler and you should be good to go. The only issue I ran into, was addressed in this post: https://forums.adobe.com/message/4823092
