• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Air 17 can't compile ipa if using custom iOS .framework on WIN
Participant ,
Mar 21, 2015 Mar 21, 2015
Hi Support,
I just encountered a problem which seems to be a bug... I am building an air native extension which uses a third-party .framework.... to be able to build my .ane I have to install the third-party framework into my flex SDK at "flex_sdk_4.6_air_sdk_17-124\lib\aot\stub" and when I run to compile my .ipa it says:
ld: in D:\\flex_sdk_4.6_air_sdk_17-124\\lib\\aot/stub/thirdParty.framework/thirdParty(coutln.o), unsupported address encoding (80) of personality function in CIE for architecture arm64
Compilation failed while executing : ld64
The weird thing is that I get this error when I'm compiling on a windows only! when I compile the very same project on a mac, it compiles just fine and I can install the .ipa with no problem!
so, I thought maybe I should post this bug here and hopefully wait for a fix because although we can live with compiling on a mac, we really need to be able to do it on a windows as we have only one Mac in the office and all the other computers are Windows!
If this is not a bug and I'm doing something wrong, please give me a hint.
Hadi
TOPICS
Performance issues
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Mar 28, 2015 Mar 28, 2015
I had this issue with an ANE I was using - it threw this error trying to build on Windows iOS. After many headaches the problem was nailed down to a problem with ld64.exe - however there's a version below that fixes the issue for me:-
http://joep.com/ld64.zip
You need to copy it over ld64.exe in flexairsdk\4.6.0+17.0.0\lib\aot\bin\ld64
Votes
Translate
Translate
Adobe Employee ,
Mar 25, 2015 Mar 25, 2015
Thanks for reporting the issue.
Could you please share a sample project so that we could reproduce the problem at our end.
Regards,
Mayank
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
Participant ,
Mar 31, 2015 Mar 31, 2015
cool, I was able to compile the .ipa with your suggested file but I have two questions:
1) what is the source of this new ld64.exe ? I mean, where did you get it from? is it official or something?
2) the compiled .ipa won't be installed on my device! it remains black after I install it through iTunes! did you experience the same problem?
Votes
Translate
Translate
Report
Report
1) The ld64.exe was sent to me by the developers of an ANE that failed to build correctly on Windows with exactly this error. I don't know whether it was them or Adobe that built it, but I trust the developers, and know they'd been in contact with Adobe (I think with premium support) to try and get a fix for this issue.
2) I've never had this problem - the IPAs I built with this linker work just like any other.
Votes
Translate
Translate
Report
Report
Participant ,
Awesome. using your solution + updating iTunes to the latest version + removing the following from plist, solved the problem. thank you
http://stackoverflow.com/questions/15081935/receiving-installation-error-applicationverificationfail...
<Entitlements>
  <![CDATA[
<key>get-task-allow</key>
<true/>
</Entitlements>
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 17, 2017 Jul 17, 2017
Thanks you ld64.exe fixed the problem
however it's size 10 times less than original ld64.exe that comes with air sdk.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Adobe should hire more competent stuff for support.
All i see just a copy paste answer asking to provide example project file to investigate.
Votes
Translate
Translate
Report
Report
