4 Replies Latest reply on Feb 8, 2007 12:42 PM by Newsgroup_User
    Gradient + Transparency Blend
    SpringTank Level 1
      I am trying to do a gradient fill to an object with one color, and the second "color" would actually be transparent.
      I was wondering if this is possible to do in Fireworks, or if anyone knows a plugin to do so?
      Thanks a Bunch!
        • 1. Re: Gradient + Transparency Blend
          Level 7
          Sure. In the box that pops up when you click on the colour box to the left
          of the Gradient description in the Property Inspector. The two small 'chips'
          that define the colours, just above the preset. The 'chips on the top row
          define the transparency. Click on one and adjust from zero to 100.
          Peter
          ____________________
          "SpringTank" <webforumsuser@macromedia.com> wrote in message
          news:eqf7js$6mr$1@forums.macromedia.com...
          second
          a
          | plugin to do so?
          | Thanks a Bunch!
          • 2. Re: Gradient + Transparency Blend
            SpringTank Level 1
            Ahh thanks :)
            is there a way to convert a bitmap's shape to a path?
            thanks
            • 3. Re: Gradient + Transparency Blend
              Level 7
              There is in FWs 8 but not in previous versions.
              news:eqfe1b$ecj$1@forums.macromedia.com...
              | Ahh thanks :)
              | thanks
              • 4. Re: Gradient + Transparency Blend
                Level 7
                Yep, but, to be clear, that's just for the outline of the non
                transparent pixels in the bitmap objects. To really *trace* a bitmap,
                you'll need to use Flash, FreeHand or Illustrator CS2 (in that order of
                better and better results).
                Stéphane Bergeron
                reach:connect:communicate
                www.webfocusdesign.com
                blog:tutorials:articles:gallery
                www.pixelyzed.com
