1 Reply Latest reply on Oct 26, 2006 3:05 PM by Newsgroup_User
    ComboBox assistance
    Brenton07
      I am working on a flash file that will allow an admin to upload and customize database entries without going into MYSQL. Part of that is designating categories. I want a simple set where the user selects something from mycombobox, and depending on which one they choose, it populates another combobox with different options. I have been trying just moving from combobox to listbox to make things simpler, but I've tried it both ways, and the code doesn't work, and I don't see why. I based this off an old tutorial, perhaps it's coded wrong? I am working in Flash 8, AS 2.0. .... HELP!!??
        • 1. Re: ComboBox assistance
          Level 7
          Brenton07,
          Here's a little snippet for you that might help you on your way:
          //get some data into the comboBox
          mycomboBox.addItem({label:"item1",data:"item1"})
          mycomboBox.addItem({label:"item2",data:"item2"})
          mycomboBox.addItem({label:"item3",data:"item3"})
          //listener to add the label & data of the selected item in the comboBox to
          the listBox
          var listenerObject:Object = new Object();
          listenerObject.change = function(eventObject:Object) {
          mylistBox.addItem({label:mycomboBox.selectedItem.label,data:mycomboBox.selectedItem.label })
          mycomboBox.addEventListener("change", listenerObject)
          hth
          Dan Mode
          --> Adobe Community Expert
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          *THE online Radio* http://www.tornadostream.com
          *Must Read* http://www.smithmediafusion.com/blog
          "Brenton07" <webforumsuser@macromedia.com> wrote in message
          news:ehr8d1$obe$1@forums.macromedia.com...
          >customize
          > combobox
          > code
          > perhaps
          > onSelect = function () {
          > text = mycombobox.getValue()
          > onChanged = function () {
          > if (mycomboBox.getValue() == "null") {
          > mylistBox.removeAll();
          > mylistBox.addItem("Please Select One");
          > if (mycomboBox.getValue() == "Movies") {
          > mylistBox.addItem("Comedy", "com");
          > mylistBox.addItem("Drama", "dra");
          > mylistBox.addItem("Mystery", "myst");
          > mylistBox.addItem("Adventure", "adv");
          > mylistBox.addItem("Sci-Fi", "scifi");
          > mylistBox.addItem("Western", "west");
          > mylistBox.addItem("War", "war");
