2 Replies Latest reply on Mar 24, 2015 3:08 AM by c.pfaffenbichler
    How can I reference a custom shape's name?
    RamoCole
      When you create a custom shape you are allowed to give that custom shape a name. I want to create a script that alerts a custom shape's name. How can I therefore store a custom shapes name in a variable or in any way reference this name?
      The intended procedure is to reference the custom shape name so I can manipulate it upon creation of said custom shape.
      I activated script listener and I can see that when I create a custom shape that is named scissors 2 the log file records this code in relation with the name:
          var desc41 = new ActionDescriptor();
          var idNm = charIDToTypeID( "Nm  " );
           desc41.putString( idNm, """Scissors 2""" );
      This other, is all the code that is created in the log file when I create a custom shape:
      var idslct = charIDToTypeID( "slct" );
          var desc36 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
              var ref14 = new ActionReference();
              var idcustomShapeTool = stringIDToTypeID( "customShapeTool" );
              ref14.putClass( idcustomShapeTool );
          desc36.putReference( idnull, ref14 );
          var iddontRecord = stringIDToTypeID( "dontRecord" );
          desc36.putBoolean( iddontRecord, true );
          var idforceNotify = stringIDToTypeID( "forceNotify" );
          desc36.putBoolean( idforceNotify, true );
      executeAction( idslct, desc36, DialogModes.NO );
      var idMk = charIDToTypeID( "Mk  " );
          var desc37 = new ActionDescriptor();
              var ref15 = new ActionReference();
              var idcontentLayer = stringIDToTypeID( "contentLayer" );
              ref15.putClass( idcontentLayer );
          desc37.putReference( idnull, ref15 );
          var idUsng = charIDToTypeID( "Usng" );
              var desc38 = new ActionDescriptor();
              var idType = charIDToTypeID( "Type" );
                  var desc39 = new ActionDescriptor();
                  var idClr = charIDToTypeID( "Clr " );
                      var desc40 = new ActionDescriptor();
                      var idRd = charIDToTypeID( "Rd  " );
                      desc40.putDouble( idRd, 0.000000 );
                      var idGrn = charIDToTypeID( "Grn " );
                      desc40.putDouble( idGrn, 0.000000 );
                      var idBl = charIDToTypeID( "Bl  " );
                      desc40.putDouble( idBl, 0.000000 );
                  var idRGBC = charIDToTypeID( "RGBC" );
                  desc39.putObject( idClr, idRGBC, desc40 );
              var idsolidColorLayer = stringIDToTypeID( "solidColorLayer" );
              desc38.putObject( idType, idsolidColorLayer, desc39 );
              var idShp = charIDToTypeID( "Shp " );
                  var idTop = charIDToTypeID( "Top " );
                  var idRlt = charIDToTypeID( "#Rlt" );
                  desc41.putUnitDouble( idTop, idRlt, 89.000019 );
                  var idLeft = charIDToTypeID( "Left" );
                  desc41.putUnitDouble( idLeft, idRlt, 232.000049 );
                  var idBtom = charIDToTypeID( "Btom" );
                  desc41.putUnitDouble( idBtom, idRlt, 131.000028 );
                  var idRght = charIDToTypeID( "Rght" );
                  desc41.putUnitDouble( idRght, idRlt, 293.000062 );
              var idcustomShape = stringIDToTypeID( "customShape" );
              desc38.putObject( idShp, idcustomShape, desc41 );
          desc37.putObject( idUsng, idcontentLayer, desc38 );
      executeAction( idMk, desc37, DialogModes.NO );
      Thanks & hope you can help
        • 1. Re: How can I reference a custom shape's name?
          The problem I had when defining custom shapes had more to do with deleting defined custom shapes.  While it was easy to define a custom shape and name it.  The name does not have to be unique.  So if a shape was already defined with the name when yow went to add a shape with the  name you just defined you would add the other shape.   Shaped are deleted by an index into the defined  shapes the users has loaded not by name.  I also did not want to delete a shaped I did not define.  So I added a timestamp suffix to the shape names I defined to make the unique. So I could use the name I defined this run.    This is good and bad If you define X you actually define XTimestamp so every time you define X you define the next version of X.  Is useable but users does not know the version name they can select  last X in the pull-down menu and the can delete prior X in in the pull-down menu.   Its not a problem if you only define one X for you select the shape from the icon in the pull-down menu no by name.
          Here is a link the the script I wrote that uses a stand alone application to trace a black and white  grayscale image into a Black and transparent file which I select its transparency and define a custom shape and I add a shape layer over the original black and white grayscale image for comparison.
          http://www.mouseprints.net/old/dpr/potrace.jsx
          Photoshop Script  Black and White Raster to Vector
          • 2. Re: How can I reference a custom shape's name?
            c.pfaffenbichler Level 9
            I’m still not sure what you are trying to achieve ultimately …
            // create custom shape and alert chosen name;
            // 2015, use it at your own risk;
            #target photoshop
            if (app.documents.length > 0) {
            alert (customShape ())
            function customShape () {
            try {
                var desc4 = new ActionDescriptor();
                    var ref2 = new ActionReference();
                    ref2.putClass( idcustomShape );
                desc4.putReference( idnull, ref2 );
                    var ref3 = new ActionReference();
                    var idPrpr = charIDToTypeID( "Prpr" );
                    var idfsel = charIDToTypeID( "fsel" );
                    ref3.putProperty( idPrpr, idfsel );
                    var idDcmn = charIDToTypeID( "Dcmn" );
                    var idOrdn = charIDToTypeID( "Ordn" );
                    var idTrgt = charIDToTypeID( "Trgt" );
                    ref3.putEnumerated( idDcmn, idOrdn, idTrgt );
                desc4.putReference( idUsng, ref3 );
                desc4.putString( idNm, "x1" );
            var aaa = executeAction( idMk, desc4, DialogModes.ALL );
            // evaluate name;
            var theName = aaa.getString (charIDToTypeID( "Nm  " ));
            return theName
            } catch (e) {}
