3 Replies Latest reply on Jan 3, 2017 11:24 AM by whatalotofrubbish
    Attach text UNDER path
    HeadNClouds Level 1
      I know I've done this before but I can't figure it out or find it - how do I attach the TOP of my text to the BOTTOM of a path? I can attach the text to the path, but its default is the bottom of the text to the inside of the path. I want to attach it to the outside, so that that TOP of the text follows the curve. It's driving me IN-SANE.
        • 1. Re: Attach text UNDER path
          Level 7
          Select the text with the Text Tool and change the Text offset (in the
          Properties Panel) to a negative value.
          alex
          • 2. Re: Attach text UNDER path
            Level 7
            Correction!
            Use the Baseline Shift and give it a negative number.
            > alex
            • 3. Re: Attach text UNDER path
              whatalotofrubbish Level 1
              Try doing that inside a circle.
              Does not function at all. Any ideas why?
              If the text sits on the outside right of the clricle, setting a minus moves it to the outside left of the same circle.
              How do you get it to hang from under a circle? Or from inside a doughnut shape?
              What is the Basline Shift Icon?
              If it is the unlabelled one with two A and one upward pointing arrow, it makes no difference that I can see, and its not mentioned as such in the help files
