1. Re: InDesign Paragraph Style won't apply / change
Peter Spier Mar 23, 2015 10:46 AM (in response to BC00)You can only apply a style to all text in a frame by selecting the frame if the frame is not threaded to others.
2. Re: InDesign Paragraph Style won't apply / change
BC00 Mar 23, 2015 11:03 AM (in response to Peter Spier)P Spier, thank you very much. What is the work around then to achieve this? Simply selecting all the text in all of the threaded frames and applying the Paragraph Style directly to them? Is it possible to select all of the threaded frames at the same time and apply the Paragraph Style to it? Advice for best method of practice is much appreciated.
3. Re: InDesign Paragraph Style won't apply / change
Willi Adelberger Mar 23, 2015 11:12 AM (in response to BC00)Depends what you want afford. If you select all, you can click on a paragraph style.
If you have defined a next style, you can define a sequence to all selected text with right mouse click on the text style.
4. Re: InDesign Paragraph Style won't apply / change
BC00 Mar 23, 2015 12:20 PM (in response to BC00)Excellent, much appreciated P Spier. Thanks for the help.
5. Re: InDesign Paragraph Style won't apply / change
Peter Spier Mar 23, 2015 12:29 PM (in response to BC00)You should be thanking Willi for the last response...
