13 Replies Latest reply on Mar 26, 2015 12:58 PM by maria__
    Flash Player auto-update fails to perform major updates
    Craig A Terlau
      I'm managing Flash Player on a large number of Intel Mac computers.  I have enabled the auto-update feature.  Auto-update seems to work for minor updates (for example current version and update version are both 16.x.x).  However the auto-update consistently fails to perform major version updates (for example from 16.x to 17.x).
      mms.cfg file location:
      /Library/Application Support/Macromedia/mms.cfg
      contents:
      AutoUpdateDisable=0
      SilentAutoUpdateEnable=1
        • 1. Re: Flash Player auto-update fails to perform major updates
          maria__ Adobe Employee
          Flash Player 17 was what is referred to as a 'loud' release and is distributed via the adobe.com site and not via silent auto-update.  This blog post An outline of Flash Runtime installation options, specifically the 'Installation Options' section) provides more information.  If you license Flash Player for distribution, the blog post, and the Flash Player Administrator's Guide offer various options for organizations to update Flash Player without the possible delay of the 'loud' releases.  I'm happy to answer questions on the update options you may have after reviewing the blog post and the Administrator's guide.
          Maria
          • 2. Re: Flash Player auto-update fails to perform major updates
            Craig A Terlau Level 1
            Hi Maria, I've read through these resources, and I see there are 8 silent
            updates and 4 loud updates per year.  The auto update feature will apply
            the 8 silent updates, but what is problematic are the loud updates.
            The update workflow currently:
            With loud updates, users are notified to update Flash - however they do not
            have administrative privileges to do this - which creates frustration and
            confusion, specifically towards Adobe Flash Player.
            Until the update is applied, their browser will no longer view Flash
            content because the browser plug-in becomes disabled - more frustration for
            end users.
            Due to the above, IT staff is notified by end users of their troubles with
            Adobe Flash Player.  IT staff enters react-to-trouble mode and downloads
            the package installer for the new loud update and pushes it out to a large
            number of machines.  Repeat this 4 times per year.
            How do we automate the application of Adobe Flash Player loud updates?  We
            are a strictly Mac environment.
            Craig Terlau
            • 3. Re: Flash Player auto-update fails to perform major updates
              Hi Craig,
              In this situation, I see the following two options:
              • Host the Background Update resources locally, information on page
                • by hosting the resources locally, Notification Updates will not occur
                • information on configuring a local server is on page 20 of the Admin Guide in the 'Background updates from an internal server' section
              • Deploy Flash Player via a software deployment solution, such as Casper or any other similar software available on Mac using the PKG installer
                • this is not the PKG installer that is extracted from the APP installer, as you'll find mentioned on several sites on the internet, but an actual PKG installer available to organizations that have Mac environments
              Both of these solutions require licensing Flash Player, if you're organization hasn't done so yet.
              Maria
              • 4. Re: Flash Player auto-update fails to perform major updates
                For the first option, If I host background updates hosted locally, will the
                'loud' updates be applied silently?
                For the second option of deploying loud updates using the PKG installer,
                can I do this before the user is notified about the update?  How will I be
                notified that a loud update is available so that I can apply it proactively?
                • 5. Re: Flash Player auto-update fails to perform major updates
                  Hi Craig,
                  For the first question, yes.  You would download the resources and deploy them to your local server.  You would then deploy a custom mms.cfg file to each system so that it knows to retrieve the updates from the local server, instead of Adobe's servers.  As long as the systems are configured this way, and you deploy the updated resources to your server when they are released, each system in your org will update using the files on the local server
                  For the second question, generally IT Admins who deploy Flash Player via some sort of software deployment solution disable AutoUpdates, by deploying a custom mms.cfg to the systems they manage disabling AutoUpdates as they want to control when the updates are released.
                  Flash Player releases generally occur once per month.  You can register to be notified when updates are available on the Security Bulletins and Advisories website.
                  Maria
                  • 6. Re: Flash Player auto-update fails to perform major updates
                    Hi Maria,
                    I want to try hosting the the Flash Player updates internally on a web
                    server.  We are already approved for Flash distribution, so I have access
                    to the files.
                    I have setup an internal web server with the update files, and I have
                    edited the mms.cfg file on some test computers to reference the internal
                    update server.  Here is my setup:
                    ###SERVER:
                    On the update server, the web root is:
                    /Library/Server/Web/Data/Sites/Default/
                    I've created this path off the web root:
                    pub/flashplayer/update/current/sau/
                    In sau/ I've placed the expanded collection of update files:
                    "fp_background_update"
                    ###CLIENTS
                    On the test clients, I've created this file:
                    With these contents:
                    AutoUpdateDisable=0
                    SilentAutoUpdateServerDomain=mdm-mapledale.k12.wi.us
                    Is this all I need to do?
                    How do I kick of Flash Player on a client Mac to do an update to test
                    whether this is working?
                    Will this setup apply both silent and loud updates?
                    Craig Terlau
                    • 7. Re: Flash Player auto-update fails to perform major updates
                      Hi Craig,
                      Can you verify if your server is configured as follows:
                      • Open port 80 for HTTP requests.
                      • Open port 443 for HTTPS requests.
                      • A valid SSL certificate for HTTPS access on port 443.
                      If you don't have this, then Background Updates won't work.
                      In your mms.cfg file, add 'SilentAutoUpdateVerboseLogging=1'. This enables verbose logging for SAU. Should things not work properly it'll help us debug why.
                      To trigger Background Updates:
                      • On Windows:
                        • Launch Control Panel and navigate to Administrative Tools > Services
                        • Run the Adobe Flash Player Update Service
                      • On Mac:
                        • Launch Terminal app
                        • Navigate to the Flash Player Launch Daemon location: /Library/Application Support/Adobe/Flash Player Install Manager/
                        • Execute the Daemon as root, at the prompt type: sudo ./fpsaud
                        • Enter root password when prompted.
                        • The SAU Daemon will execute. When finished, it will return to the terminal prompt.
                      Hosting Background Updates locally disables Notification Updates, so users will only receive updates from you local server.
                      Maria
                      • 8. Re: Flash Player auto-update fails to perform major updates
                        Thanks Maria, I'll give this a try.
                        What is the location of the log file on Mac when I add
                        to mms.cfg?
                        Craig
                        • 9. Re: Flash Player auto-update fails to perform major updates
                          Hi Craig,
                          Sorry, I forgot to include that.  Flash Player log files are located as follows:
                          • Mac:
                            • Users ~/Library/Logs/FlashPlayerInstallManager.log
                          • Windows 32-bit:
                            • C:\Windows\System32\Macromed\Flash\FlashInstall.log
                          • Windows 64-bit:
                            • C:\Windows\System32\Macromed\Flash\FlashInstall.log AND
                            • C:\Windows\SysWOW64\Macromed\Flash\FlashInstall.log
                          Maria
                          • 10. Re: Flash Player auto-update fails to perform major updates
                            So, here is what I see in the log file.  It looks like it worked, but I am
                            still at 160.0.0.305.
                            sh-3.2# cat /Users/admin/Library/Logs/FlashPlayerInstallManager.log
                            2015-03-02 13:20:59 -0600   IM:
                            • 11. Re: Flash Player auto-update fails to perform major updates
                              Can you post everything between the ----log start---- and ----log end----
                              Do you see a file named FPSAUConfig.xml in /Library/Application Support/Adobe/Flash Player Install Manager/? If so, please delete the file and run SAU again.
                              • 12. Re: Flash Player auto-update fails to perform major updates
                                Hi Maria,
                                So this is the log entry:
                                2015-03-26 14:07:04 -0500  SAU:
                                • 13. Re: Flash Player auto-update fails to perform major updates
                                  Hi Craig,
                                  The log file should contain more information than that.  It should look something like the following (in this case, no update was found).
                                  2015-03-25 18:14:17 -0700 [I] SAU: ---------- log start ----------
                                  2015-03-25 18:14:17 -0700 [I] SAU: Starting SAU
                                  2015-03-25 18:14:17 -0700 [I] SAU: End SAU run with exit code: 0
                                  2015-03-25 18:14:17 -0700 [I] SAU: ----------  log end  ----------
                                  When posting the contents of the log file, please post them as I have above, or upload the entire file using the instructions here https://forums.adobe.com/thread/1408375.
                                  Maria
