1 Reply Latest reply on Mar 23, 2015 3:59 PM by A.T. Romano
    Premier audio timing
    Larry B Val Vista
      Audio timing is off on DVD made from Premier.
      iPad video of show edited and then DVD made.
      Audio timing is off.
      How can I prevent or correct?
        • 1. Re: Premier audio timing
          A.T. Romano Level 7
          larry b val vista
          What is your program? Premiere Pro or Premiere Elements? Assuming Premiere Elements for now....
          What version of Premiere Elements and on what computer operating system is it running?
          iPad video is often recorded with a variable frame rate. Premiere Elements does not fare well with variable
          frame rates. Problems range from out of sync audio to not being able to import the video at all. One solution is to use a free program such as HandBrake to convert the file with the variable frame rate to a constant one - produces H.264.mp4 file.
          https://handbrake.fr/
          More information can be supplied after you review the above and supply more information.
          Thank you.
          ATR
