1 Reply Latest reply on May 8, 2006 8:46 AM by coderhead
    How to intercept property changes in subclassed control?
      I've got an application in Flex 1.5 that uses constants stored in XML files (see attached). The XML files are loaded into mx:Models and used as dataProviders on ComboBoxes with "abbr" as the labelItem. The business objects store only the numeric ID of the constants. When a business object is loaded, I need to set the selectedItem of the ComboBox using the numeric ID but I can't because it doesn't match the items in the dataProvider.
      Is it possible to intercept the selectedItem property change and process the dataProvider items in order to compare the numeric values instead of having to process it in a function outside of the control itself? I'd like to write this code only once.
