0 Replies Latest reply on Mar 24, 2015 12:31 AM by elmer_banate
    Create XML Element Tag BasedOn Found Character Style
    elmer_banate
      Good Day!
      Basically I want to search only for character styles that contains "ntb-", that is why it is hard coded in my searchString variable.
      Although I was able to create XML tag based on selected character style, but it will always add/insert at the end of the parent XML element.
      Can anyone could help me how insert/add that element at the insertion point where the text is found?
      --elmer
      var myDoc = app.documents[0];
      myDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.POINTS;
      myDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.POINTS;
      var charStyles = myDoc.allCharacterStyles;
      var foundStyles = Array();
      var searchString = String();
          searchString = 'ntb-';
      var tempName = String();
      var tempName1 = String();
      for(var i = 1; charStyles.length > i; i++){
         tempName = charStyles[i].name;
         tempName1 = tempName.toLowerCase();
         if(tempName1.indexOf (searchString.toLowerCase()) != -1){
             foundStyles.push (tempName);
      var myDialog = app.dialogs.add({name: "Convert Footnote Character Styles to XML Tags",canCancel:true});
      with (myDialog) {
          with (dialogColumns.add().borderPanels.add()) {
              with (dialogColumns.add()) {
                  staticTexts.add({staticLabel: "Character style to search : "});        }
                  selCharStyle = dropdowns.add({stringList: foundStyles, selectedIndex: 0, minWidth: 175});
      var dialogShown = myDialog.show();
      while (dialogShown) {
          if (selCharStyle.selectedIndex == 0) {
              alert("Must have at least a character style to search!");
              continue;
          } else {
              insertXMLTags(selCharStyle.stringList[selCharStyle.selectedIndex], selCharStyle.selectedIndex, "0");
              break;
      myDialog.destroy();
      alert("Finished!");
      exit();
      function insertXMLTags(cStyle, cStyleIndex, ip) {
          var myFinds = searchStyle(cStyle, cStyleIndex);
          for (i=myFinds.length - 1; i>=0; i--) {
              var myIP = myFinds[i].texts.item(0).insertionPoints.item(0);
              var myParentXML = myIP.associatedXMLElements[0];
              var myChiidXML = myParentXML.xmlElements.add ( cStyle );
              myChiidXML.contents =  myFinds[i].contents;
              //set the selection
              app.selection = myFinds[i].texts.item(0);
              //remove the selected text
              myFinds[i].texts.item(0).remove();
              Utility Functions
      function searchStyle(cStyle, cStyleIndex){
          var myFinds;
          // if script version is for Indesign CS2
          if (app.scriptPreferences.version < 5){
              app.findPreferences = NothingEnum.nothing;
              app.changePreferences = NothingEnum.nothing;
              myFinds = myDoc.search(undefined, undefined, undefined, undefined,
              {appliedParagraphStyle: pStyle, appliedCharacterStyle: cStyle});
          // else, for CS3 and CS4
          }else{
              //Clear any existing find/change settings
              app.findTextPreferences = NothingEnum.nothing;
              app.changeTextPreferences = NothingEnum.nothing;
              // set character or paragraph style to search
              if (cStyleIndex != 0){
                  app.findTextPreferences.appliedCharacterStyle = cStyle;
              //Set the find options.
              app.findChangeTextOptions.caseSensitive = false;
              app.findChangeTextOptions.includeFootnotes = true;
              app.findChangeTextOptions.includeHiddenLayers = false;
              app.findChangeTextOptions.includeLockedLayersForFind = false;
              app.findChangeTextOptions.includeLockedStoriesForFind = false;
              app.findChangeTextOptions.includeMasterPages = false;
              app.findChangeTextOptions.wholeWord = false;
              myFinds = myDoc.findText();
          return myFinds;
