2 Replies Latest reply on Feb 11, 2007 6:26 PM by rui_yangrh
    DateChooser - Not allowing deselection
    tnirenstein Level 1
      I am using a DateChooser control which I default to the current date. If the user clicks on a selected date, it unselects that date. Is there a way to force a selection so if the user clicks on the currently selected date, nothing will happen?
      Thanks in advance!
        • 1. Re: DateChooser - Not allowing deselection
          rui_yangrh Level 1
          hi, tnirenstein
          I met this problem when I using a DateField component. And I use a variable to store the currentlydate. if the user clicks on the currently selected date again, set the value of currentlydate variable back to the 'selectedDate' property. My english is not well, I hope the following code be useful to you.
          <?xml version="1.0"?>
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml">
          <mx:Script>
          <![CDATA[
          import mx.events.CalendarLayoutChangeEvent;
          private var date:Date;
          private function OnChange(evt:CalendarLayoutChangeEvent):void
          if(DateField(evt.currentTarget).text == "")
          df.selectedDate = date;
          else
          date = df.selectedDate;
          </mx:Script>
          <mx:DateField id="df" change="OnChange(event);"/>
          </mx:Application>
          • 2. Re: DateChooser - Not allowing deselection
            rui_yangrh Level 1
            I searched the web and found someone extends DataChooser Class to solve this problem, following is the content of the actionscript file named "NewDateChooser.as":
            package
            import mx.controls.DateChooser;
            import mx.controls.CalendarLayout;
            import mx.core.mx_internal;
            import mx.events.DateChooserEvent;
            use namespace mx_internal;
            public class NewDateChooser extends DateChooser
            //Constructor
            public function NewDateChooser()
            super();
            override protected function createChildren():void
            super.createChildren();
            if (mx_internal::dateGrid)
            removeChild(dateGrid);
            mx_internal::dateGrid = new CalendarLayout();
            dateGrid.styleName = this;
            addChild(dateGrid);
            dateGrid.addEventListener(CalendarLayoutChangeEvent.CHANGE,
            changeHandler);
            dateGrid.addEventListener(DateChooserEvent.SCROLL,
            scrollHandler);
            * @private
            private function scrollHandler(event:DateChooserEvent):void
            dispatchEvent(event);
            * @private
            private function changeHandler(event:CalendarLayoutChangeEvent):void
            if (selectedDate == event.newDate)
            selectedDate = event.newDate;
            else
            selectedDate = CalendarLayout(event.target).selectedDate;
            var e:CalendarLayoutChangeEvent = new
            CalendarLayoutChangeEvent(CalendarLayoutChangeEvent.CHANGE);
            e.newDate = event.newDate;
            e.triggerEvent = event.triggerEvent;
            dispatchEvent(e);
