I can't download and install the Creative Cloud.
I receive each 5 minutes following error:
The server is not responding currently, please try after some time. (Error code: 207)
I have this error since yesterday and I have still this error.
Also tested on more than 1 computer. (Windows 7 en 8.1)
DLM.log:
03/24/15 10:07:39:743 | [ERROR] | | | | | | | 9984 | The windows error code is - 12002
03/24/15 10:07:39:743 | [ERROR] | | | | | | | 9984 | Failed to send the request to server to get the response - 12002
03/24/15 10:07:39:743 | [ERROR] | | | | | | | 9984 | the download job (0) failed to execute. The job state is STOPPED_STATE
03/24/15 10:07:40:253 | [INFO] | | | | | | | 12084 | Retry count overshoot for http_timeout_error - 13
03/24/15 10:07:43:742 | [ERROR] | | | | | | | 7660 | The windows error code is - 12002
03/24/15 10:07:43:742 | [ERROR] | | | | | | | 7660 | Failed to send the request to server to get the response - 12002
03/24/15 10:07:43:742 | [ERROR] | | | | | | | 7660 | the download job (1) failed to execute. The job state is STOPPED_STATE
03/24/15 10:07:59:742 | [ERROR] | | | | | | | 9984 | The windows error code is - 12002
03/24/15 10:07:59:742 | [ERROR] | | | | | | | 9984 | Failed to send the request to server to get the response - 12002
LBS.log:
03/24/15 10:03:37:309 | [INFO] | | ACC | LBS | ETS | | HTTPConnector | 6860 | HTTP Request Status code 200.
03/24/15 10:03:37:309 | [INFO] | | ACC | LBS | ETS | | HTTPConnector | 9552 | The http request returned HTTP_Status:0 HttpCommunicator error:0
03/24/15 10:07:59:846 | [INFO] | | ACC | LBS | ETS | | | 15492 | Event Guid generated is: '81c6e84f-d697-4850-9bc1-ff0465caea10'
03/24/15 10:07:59:846 | [INFO] | | ACC | LBS | ETS | | | 9552 | Event with guid '81c6e84f-d697-4850-9bc1-ff0465caea10' is being sent
03/24/15 10:07:59:858 | [INFO] | | ACC | LBS | ETS | | HTTPConnector | 9552 | GetIEProxyInfo - No default proxy present on the user machine
03/24/15 10:07:59:858 | [INFO] | | ACC | LBS | ETS | | HTTPConnector | 9552 | GetIEProxyInfo - Failed to get proxy for the url, error:12006
03/24/15 10:08:00:323 | [INFO] | | ACC | LBS | ETS | | HTTPConnector | 9060 | HTTP Request Status code 200.
03/24/15 10:08:00:323 | [INFO] | | ACC | LBS | ETS | | HTTPConnector | 9552 | The http request returned HTTP_Status:0 HttpCommunicator error:0
Well, obviously there is something specific to your network configuration... Check this as a start:
Sign in, activation, or connection errors | CS5.5 and later
Mylenium
I also tested this on a external network and it doesn't work (modem -> router -> pc AND everything allowed in router).
Everything works but on https://activate.adobe.com/test I receive access denied. (Also on another network)
Maximeg73172082 are you able to run success Ping and Traceroute reports on the addresses identified in the DLM.log?
Yes
Maximeg73172082 if you were successful then there is something else in the local network topology which is causing the failures. I would recommend reviewing proxy servers and any hardware and software firewalls settings to determine the cause of the failure.
