We have a new install windows server 2012 R2 with a new install CF11 standard installed on C drive. Everything is 64bit. The CF administrator site and login works fine. cfm files will not serve up in the default directory, but IIS shows htm files fine. CF administrator runs fine.
Web Server Config tool will only show "None" in the IIS Web Site box. The usual CGI, APS, etc have been installed on IIS. In fact IIS and CF11 have been reinstalled. wsconfig.exe manual run shows no errors.
The problem is that any call to a cfm template results in an error (html pages serve fine):
HTTP Error 500.0 - Internal Server Error
The page cannot be displayed because an internal server error has occurred.
Detailed Error Information:
Module IsapiModule
Notification ExecuteRequestHandler
Handler cfmHandler
Error Code 0x8007007f
Requested URL http://localhost:80/default.cfm
Physical Path C:\inetpub\wwwroot\default.cfm
Can anybody give any suggestions for troubleshooting? No logs seem to show any information that helps.
Fixed the problem......... it is not a CF problem alone but and mostly an IIS problem ....
1) remove IIS completely...... including the inetpub directory..... remove .NET Extensibility from server manager under Application Development if inetpub in use error is present... inetpub has to be deleted.
2) reboot
3) reinstall IIS and enable all the usual stuff, ie, CGI, ISAPI, .NET, ASP , WebSocket Protocol, etc under Application Development
4) restart IIS and CF
5) Set Web Server Config to "All"
60 resta
...Copy link to clipboard
Perhaps run WSCONFIG as administrator?
Is there a ColdFusion11\config\wsconfig\1 folder present with a DLL log and properties files?
HTH, Carl.
Thank you for your response.
I had tried running wsconfig as admin as suggested elsewhere and it makes no difference. The WSCONFIG GUI "IIS Web Site" box only shows "None" and no other selection. There is no "1" subdirectory of wsconfig. wsconfig folder contains two files...... cfwin32.dll and wsconfig.log . If I temporarily remove those two files, running WSCONFIG does put them back in.
Also:
Running
PS C:\coldfusion11\cfusion\bin\connectors> ./IIS_ConnectorList.bat
This lists all configured connectors. For IIS, it lists configured and unconfigured connectors.
Press Control+C to abort.
Press any key to continue . . .
There are no configured web servers
Running
PS C:\coldfusion11\cfusion\bin\connectors> ./IIS_connector.bat
WARNING! This will install the ColdFusion IIS Connector at the global level.
1
there is no wsconfig\1 folder created if that is what the return of number "1" means
2) reboot
60 restart IIS and CF
The trick to completely reinstall IIS and that is only done if you can delete the inetpub folder under root drive.
