Hi all
Okay, hoping no jet lag remnants for Peter and all to tease
me about.
I don't believe I've seen anything related to what I'm about
to offer, so here goes.
Carol, have any of these topics been imported from elsewhere?
Maybe Word? My reason for asking is because I've seen it happen
more than once where you bring something in and a broken link
results. Try as you might, you cannot seem to find the link! So
here's how I approach it. I'm copying and pasting from an article I
wrote a while back.
How they can occur
1. The destination HTML page can have its name changed,
perhaps external to RoboHelp via Windows Explorer. For instance,
lets say you have a topic labeled "My Topic.htm". For some reason
or other, you choose to rename it as "My_Topic.htm" using Windows
Explorer. RoboHelp would declare any link to this topic as being
broken, because the link is looking for "My Topic.htm".
2. The destination HTML page could have begun life in a
different location. Then was later referenced by a topic using an
absolute address. In this case, c:\SomeFolder\SomeTopic.htm. Then
the topic is subsequently copied to your project and deleted from
the original location.
3. The folder containing the destination HTML page(s) could
have been renamed. In this case, particularly if the folder is
renamed outside of Robohelp HTML, all topics inside will appear as
broken links to any topic referencing them. Although, I have seen
it happen where even using RoboHelp HTML to rename the folder, some
things aren't totally updated as a result.
How to correct them
Probably the easiest way is to examine the Broken Links
folder.
1. Double click a link that is listed. A dialog should
display listing the topic(s) RoboHelp thinks the broken link is in.
2. Select the topic, then click the Edit button. This should
open the topic containing the broken link.
3. Verify any and all links in the topic. Personally, I like
to hover each link, then compare what appears in the tooltip popup
to what is displaying in the Broken Links folder. Once you see a
similar link, double click it to edit.
The ghost links
One of the most frustrating items to track down is what I
like to call the "ghost link". Here is what I mean by "ghost link".
You open the topic RoboHelp HTML is indicating has a broken link.
However, try as you might, you either don't see a link in the
WYSIWYG editor, or you don't see *THE* link being reported as
broken. To make matters worse, you can often display the TrueCode
and still fail to see it! I'm not exactly sure what is up with
these, but I usually see them when I import a topic that was
created using either Microsoft Word or Microsoft FrontPage. The
RoboHelp editor is simply doing its best to display what it finds.
I figure something in these topics is coded in a manner RoboHelp
doesn't understand. So RoboHelp can't show me the link code.
How to correct the ghost links
1. Leave RoboHelp HTML open and locate the suspect topic
using Windows Explorer.
If you have opened the topic from the broken links list, you
may not know which folder it's in (assuming you have structured
your project using folders). An easy way to locate the folder is to
right click the topic in the RoboHelp HTML editor, then select
Properties from the context menu. A quick look at the Status tab
should easily reveal the folder. Look at the second line listed. It
begins with "Location:".
2. Edit the topic using Windows Notepad.
3. Press the F3 key to invoke the Find dialog.
4. Enter the following character string into the search
dialog: <a href= and click the Find Next button.
For those of you unfamiliar with HTML coding, the <a href=
indicates the beginning of a hyperlink.
5. You will need to delete everything from <a href= to the
closing </a> tag. This will kill the hyperlink. Be certain
that the link you are working with is the suspect. This is
confirmed by comparing the .htm file being specified in the code
with the .htm file RoboHelp is reporting a problem with.
6. Close Notepad, save the file, then return to RoboHelp
HTML. Assuming you found the only instance of the errant link, the
list of broken links should have automatically updated itself so it
no longer indicates this link as broken.
Hope this helps some... Rick
