1 Reply Latest reply on Jan 29, 2007 7:17 AM by Captiv8r
    Drop Down Menu in ASP
      When capturing a asp.net application clicking the asp dropdown menu control does not capture the submenu items. It shows the cursor position but no text for the drop down part of the menu. Is there something special that needs to be done in order to capture these menu controls.
        • 1. Re: Drop Down Menu in ASP
          Hi buchbri and welcome to our community
          This sounds to me as if you possibly managed to capture a drop-down menu just before the text loaded. This is actually quite common with Captivate. Essentially here's what happens. You are recording and click an object. The click was sensed immediately and triggered a screen capture. But the screen hasn't yet had time to fully paint the result. So you end up missing a bit. When you see this occurring, you will know you need to supplement the capture with use of the Print Screen key. Keep in mind that simply because you are automatically recording doesn't mean you can't force a screen grab when you need it.
          Hopefully this helps... Rick
