1 Reply Latest reply on Jan 30, 2007 8:26 PM by Dan Bracuk
    Reserved tag override
      is it possible to override reserved coldfusion function tags?
      It seems simple but the implications would be incredible.
      Ie, I want to be able to do this
      <cfdump var="#form#">
      if form is defined, it will return form, if not, it will return NULL instead of erroring out.
      is this possible?
      In addition to this, how do i write my own cftags?
      ie
      if cfdump modification is not possible, i want to be able to type <cfPreDump var="#form#">
      etc
        • 1. Re: Reserved tag override
          Dan Bracuk Level 5
          To write your own tags, write a .cfm file with the code you want to run. Let's call it abc.cfm. To call it, you go <cf_abc>
          Many Cold Fusion reference books give you the details. Also, I just googled "coldfusion custom tags" and saw a few promising references.
