2 Replies Latest reply on Jan 30, 2007 1:35 PM by nasakick
    Combining Multiple XML files to use in Flash
      I am still fairly new at the whole Flash...XML thing but I was wondering if it is possible to combine several XML files used to build photo galleries into one single XML file that Flash could then read which gallery depending on which gallery is selected. Basically I have about 10 photo galleries and 10 XML files. Each XML file is named different and in Flash I have the gallery calling the XML file. I was thinking it would clean things up a lot and make editing easier if I can some how make one XML with all the galleries contained inside the XML then write a variable or something so Flash knew which gallery to open when activated. Similar to how you have to write the variables for a text doc file. Any help would be great.
