2 Replies Latest reply on Jan 31, 2007 11:47 AM by Linux Rules
    WebHelp in Java
    rds0121
      What are the procedures for publishing Webhelp to java war file? Is this possible? If so, what Webhelp files do I place in the war file?
        • 1. Re: WebHelp in Java
          MergeThis Level 4
          Yes it is, but you must provide ALL the files that get generated.
          Leon
          • 2. Re: WebHelp in Java
            Linux Rules Level 2
            Hello rds0121 -
            I generate the WebHelp from RH X5 to my local drive then gen the WAR file to include everything in the RH output directory. If your project is a component of a larger project, install yours first then gen the entire project WAR file. Don't forget to make changes to XML files if (if used by your developers) before creating your WAR file.
            Regards,
            gewb
