1 Reply Latest reply on Apr 8, 2015 2:14 AM by (Hector)
    MongoDB - Date insert
    (Hector)
      Has anyone experience with MongoDB and Coldfusion?
      I have problems to store a Date object correctly in MongoDB.
      I am using the Mongo-Java Driver.
        • 1. Re: MongoDB - Date insert
          (Hector) Level 1
          That is my code.
          <cfset utilDate = CreateObject("java","java.util.Date") />
          <cfset utilJSON = CreateObject("java", "com.mongodb.util.JSON") />
          <cfset SimpleDaxteFormat  = CreateObject("java", "java.text.SimpleDateFormat").init("yyyy-MM-dd'T'HH:mm:ss.SSS'Z'") />
          <cfset SimpleDateFormat2 = CreateObject("java", "java.text.SimpleDateFormat").init("yyyy-MM-dd'T'HH:mm:ss.SSS'+01:00'") />
          <cfset jodaIso = CreateObject("java", "org.joda.time.format.ISODateTimeFormat") />
          <cfset isoDate1 = "2015-03-25T15:23:57.000Z" />
          <cfset isoDate2 = "2015-03-25T15:23:57.000+01:00" />
          <cfset isoDate3 = "2015-03-25T15:23:57+01:00" />
          <!--- Joda Date-Time --->
          <cfset jMillis = jodaIso.dateTimeNoMillis() />
          <cfset jpdt = jMillis.parseDateTime(isoDate3) />
          <cfset jToDateIso = jpdt.toDateTimeISO() />
          <!--- Document data for insert : all three should be DATE Objects! --->
          <cfset doc = {
             "date1" = SimpleDateFormat.parse(isoDate1),
             "date2" = SimpleDateFormat2.parse(isoDate2),
             "date3" = jToDateIso.toDate()
          <!--- JSON parsing --->
          <cfset doc = utilJSON.parse(SerializeJSON(doc)) />
          <cfset col.save(doc) />
          Listing Document in MongoClient:
          > db.datetest.find().pretty()
              "_id" : ObjectId("5512c4fd1e106620a5b49dac"),
              "date1" : "März, 25 2015 15:23:57",
              "date2" : "März, 25 2015 15:23:57",
              "date3" : "März, 25 2015 15:23:57"
          All three column fields are strings ;(
          The fields should be Date-Objects, output should be:
          "date1" : ISODate("2015-03-25 15:23:57"), ...
