5 Replies Latest reply on Mar 26, 2015 2:40 PM by flyingj481
    Silent Install for Adobe Presenter 10
    22trebor
      I am getting an error (A valid installer cold not be found) when trying to create a package using AAMEE. I have used this in the past to package Presenter. I have targeted the path to setup.exe and set-up.exe.
        • 1. Re: Silent Install for Adobe Presenter 10
          Jeff A Wright Adobe Employee
          Moving this discussion to the Adobe Presenter forum.
          • 2. Re: Silent Install for Adobe Presenter 10
            flyingj481 Adobe Community Professional (Moderator)
            This thread may help: Re: Presenter 10 CCP
            • 3. Re: Silent Install for Adobe Presenter 10
              22trebor Level 1
              I call support for the fix. Since version 9, you have to use the CC Packager.
              ftp://cust-dl:$Zwmpl3456@sjftp.adobe.com/ccp1_8/CreativeCloudPackager_1_8_all.exe
              Instructions for creating Presenter 10 package for 64-bit OS and 32-bit PowerPoint:
              1. Please download Adobe Presenter 10 from Adobe.com or from your Adobe Licensing Website (LWS) account and extract the .7z file to a folder by double-clicking the .exe file.
              2. Once done, please launch CCP and Click “Creative Cloud for Enterprise”.
              3. Sign in using your Adobe ID and click Next.
              4. Now, click on “Create Package”.
              5. Select “Serial Number License”.
              6. For 64-bit OS and 32-bit MS Office, select “64-bit package”.
              7. Click Next and enter the serial number for Adobe Presenter 10.
              8. Now, click on “Offline Media” option at the bottom of the window and navigate to the installer for Presenter 10 extracted in step 1. You may have to select the 32-bit folder inside the extracted setup folder and then build package.
              9. Adobe Presenter 10 package is created and you would see “Builds” and “Exception” folder.
              10. Deploy the contents of build and exception folder just like you do for other products.
              • 4. Re: Silent Install for Adobe Presenter 10
                22trebor Level 1
                Well I spoke to soon. It seems that the packager does not fix the error. I am still getting an 1603 error in the log file. I ran the MSI with a /log switch to get the log file. I can manually install the program, so there no conflict with any other software.
                • 5. Re: Silent Install for Adobe Presenter 10
                  Here is a more detailed explanation from RajeevAdobe
                  Instructions for creating Presenter 10 package for 32-bit OS and 32-bit PowerPoint or for 64-bit OS and 64-bit PowerPoint:
                  1. Please launch CCP and Click “Creative Cloud for Enterprise”.
                  2. Sign in using your Adobe ID and click Next.
                  3. Now, click on “Create Package”.
                  4. Select “Serial Number License”.
                  5. For 32-bit OS and 32-bit MS Office, select “32-bit package”. For 64-bit OS and 64-bit MS Office, select “64-bit package”.
                  6. Click Next and enter the serial number for Adobe Presenter 10.
                  7. Now, select Adobe Presenter 10 from the list and create Build.
                  8. Adobe Presenter 10 package is created and you would see “Builds” and “Exception” folder.
                  9. Deploy the contents of build and exception folder just like you do for other CC products.
                  10. Deploy the contents of build and exception folder just like you do for other CC products.
                  Deployment Instructions:
                  On your  machine you have to open Command Prompt, Right click on it and select Run as administrator. In Command Prompt you have to go to the exact path where Presenter package folder is placed and go inside build folder.
                  Once you are in build folder location in Command Prompt then type the command :-    msiexec.exe /i name of the package.msi /quiet and press enter.
                  After then please open Task manager , In process tab you will see msiexec processes are running and It will install/deploy the Presenter 10 Package silently on your machine.
                  1. I would suggest you to please remove Adobe Presenter and its older components completely . Delete the left over files and folders manually for Presenter.
                  2. Disable the Firewall and Start up items.
                  3. Reboot the machine and follow the steps mentioned above to create a package and deploy it .
                  4. If you still face any issue then please send me a installation logs as private message .
                  Regards,
                  Rajeev.
