0 Replies Latest reply on Feb 1, 2007 10:05 AM by johannki
    Bug: static listener function doesn't fire in AS when useWeakReference=true
    johannki Level 1
      Note: This is an issue in ActionScript (AS) files only. It appears to work fine in .mxml files.
      For a RemoteObject within an AS file, when a static listener function is specified in addEventListener and useWeakReference=true, the listener function is never invoked.
      Using the RemoteObject example from here, if you make the file an AS file, call it from a .mxml file, change the getListResultHandler to be static and change
      employeeRO.getList.addEventListener("result", getListResultHandler);
      to
      employeeRO.getList.addEventListener("result", getListResultHandler, false, 0, true);
      the getListResultHandler function will never be invoked. However, if you change useWeakReference=false, e.g.
      employeeRO.getList.addEventListener("result", getListResultHandler, false, 0, false);
      it will be invoked. In a .mxml file, both static and non-static listener functions get invoked fine.
