2 Replies Latest reply on Feb 23, 2007 1:31 AM by simonjpalmer
    Parent Child Hierarchy with FDS and Hibernate
    simonjpalmer
      I know my chances of getting heard here are slim, but I am at a dead end, so here goes.
      I have a four level hierarchy of objects
      PlanPoint
      ....UserScenario
      ........Scenario
      ............Competitor
      which have bi-directional one-to-many relationships between them.
      I have made sure that my hibernate mappings and FDS destination are matched and I definitely need to have managed associations as the graph of objects will grow large in my application (and besides, it is good development practice). So I have a fully formed project (or at least I think I do) and I get a duplicate object error.
      Right at the bottom I have an alternative that I have tried which gives a different error.
      Here is a snippet from my log... it picks up just after the message arrives
      2007-02-05 21:21:10,281 INFO [STDOUT] Hibernate: insert into COMPETITOR (COMPETITOR_ID, SCENARIO_ID, NAME, X, Y, RADIUS, ACTUAL, PROPOSITIONS, ORDER_SIZE, CONVERSION_RATE) values (null, ?, ?, ?, ?, ?, ?, ?, ?, ?)
      2007-02-05 21:21:10,281 INFO [STDOUT] Hibernate: call identity()
      2007-02-05 21:21:10,312 INFO [STDOUT] Hibernate: insert into SCENARIO (SCENARIO_ID, TITLE, SEQUENCE, POTENTIAL, USER_SCENARIO_ID) values (null, ?, ?, ?, ?)
      2007-02-05 21:21:10,312 INFO [STDOUT] Hibernate: call identity()
      2007-02-05 21:21:10,359 INFO [STDOUT] Hibernate: insert into USER_SCENARIO (USER_SCENARIO_ID, TITLE, PLANPOINT_ID, AUTHOR) values (null, ?, ?, ?)
      2007-02-05 21:21:10,359 INFO [STDOUT] Hibernate: call identity()
      2007-02-05 21:21:10,406 INFO [STDOUT] [Flex] Serializing AMF/RTMP response
      Version: 3
      (Command method=_error (0) trxId=8)
      (Typed Object #0 'flex.messaging.messages.ErrorMessage')
      rootCause = (Typed Object #1 'org.hibernate.NonUniqueObjectException')
      throwables = (Array #2)
      [0] = (Ref #1)
      localizedMessage = "a different object with the same identifier value was already associated with the session: [pmco.pojos.Competitor#0]"
      message = "a different object with the same identifier value was already associated with the session: [pmco.pojos.Competitor#0]"
      identifier = 0
      cause = null
      throwableCount = 1
      entityName = "pmco.pojos.Competitor"
      messages = (Array #3)
      [0] = "a different object with the same identifier value was already associated with the session"
      destination = "competitor.hibernate"
      headers = (Object #4)
      correlationId = "BFAF11E0-6121-54BB-A836-93C81DAE7772"
      faultString = "Could not invoke sync method on data adapter for destination 'userscenario.hibernate' due to the following error: class org.hibernate.NonUniqueObjectException:a different object with the same identifier value was already associated with the session: [pmco.pojos.Competitor#0]."
      messageId = "78CB9396-9618-519F-8DB0-70D4E53357FE"
      faultCode = "Server.Processing"
      timeToLive = 0.0
      extendedData = null
      faultDetail = null
      clientId = null
      timestamp = 1.17071047039E12
      body = null
      Anyone got any ideas?
      I would provide my mappings and destinations but I can't fit them in a message
        • 1. Re: Parent Child Hierarchy with FDS and Hibernate
          box110a
          I have been working with very hierarchical data with FDS and EJB3.0 (hibernate on jboss4.0.5). I've avoided the direct mapping between flex and Hibernate because of scenarios like this. I don't like linking my persistence version/methodlogy directly to the front end. Instead I've used the JavaAssembler strategy that works directly with session EJBs. This has proven to work very well. Also you may be getting this error because your mappings are not correct. make sure your cascading properly. you will get this error because you're trying to insert an object that Hibernate has already inserted. hope this helps.
          -JB
          • 2. Re: Parent Child Hierarchy with FDS and Hibernate
            simonjpalmer Level 1
            thanks for the reply it was very helpful. I came to pretty much the same conclusion and started on the path of a re-write of the hibernate assembler myself. As far as I can tell the Hibernate Assembler is a Java Assembler, so there didn't seem much difference to me between fixing that one and writing another one. Adobe ship the code.
            Bit of a cheeky request, but I don't suppose you would be willing to share your assembler layer so I have a template against which to work? Biggest problem with this sort of activity is a lack of examples which makes it very slow going and largely trial and error.
            If you would like to know more about our application I will provide contact details so we can discuss.
            Simon
            PS Jeff Vroom posted a reply saying that the Adobe Hibernate Assembler didn't work properly with hierarchical data (which I imagine is every real application in the world), personally I think Adobe should fix it or pull it.
            http://tech.groups.yahoo.com/group/flexcoders/message/63961
