0 Replies Latest reply on Feb 1, 2007 8:29 AM by ashar2005
    Disable a drag copy ?
    ashar2005 Level 1
      I have 2 lists, which should be exclusive of each other, if something is taken from one list to the other
      it should not remain in the list it was taken from. I know that enabling dragMove will allow the item to be
      moved, but if a user holds down the CTRL key while doing it, it will copy it over instead of moving it.
      I thought about trying to disable the CTRL key (anybody know how ?), but thought there might be something
      similar to disabling the drag copy function, similiar to how you can disable dragMove.
      If it can only be done with making several drag functions, can you post the example of it.
      TIA
