5 Replies Latest reply on Mar 26, 2015 11:31 AM by kglad
    XML.prototype.load
    dazzfazz Level 1
      I need to extend the XML load method as so I can add a prefix onto the XML.load("my_xml_data_file_location.xml") as so the actual url request was XML.load("http://www.myServerLocation.com/my_xml_data_file_location.xml")
      So my first thought was to hijack the XML.prototype.load method but for the life of me I cannot find a reference to the XML.prototype.load function. And then I would add code to the XML.prototype.load method to query the URL string to see if it has or has not a http server URL location .
      Thanks in advance.
        • 1. Re: XML.prototype.load
          create a function that prepends that string.
          • 2. Re: XML.prototype.load
            dazzfazz Level 1
            Already thought of that one but that would need a lot of effort to trawl through inherited code and I don't have the time to do this.
            So the easiest approach I thought was to hijack the XML.prototype.load method and add the additional "checking code" into this method.
            • 3. Re: XML.prototype.load
              you don't need to hijack anything:
              yourcustomloadfunctionF(xml:XML,xmlS:String):Void{
              xml.load('yourprependedstring'+xmlS);
              • 4. Re: XML.prototype.load
                dazzfazz Level 1
                Thanks for coming back so quickly.
                I failed to add that the inherited code uses the XML.load methods in many, many locations. Hence wanting to use an extended XML.prototype.load method. That way I only need to apply this code in one place and at run time, everywhere the XML.load is used, the prototype will do all the pre-checking. Also, it will not need to add any code anywhere else.
                • 5. Re: XML.prototype.load
                  use:
                  var XMLLoad:Function=XML.prototype.load;
                  XML.prototype.load=loadF;
                  function loadF(s:String):Void{
                  XML.prototype.load=XMLLoad;
                  this.load('yourprependedstring'+s);
                  p.s when using the adobe forums, please mark helpful/correct responses, if there are any.
