3 Replies Latest reply on Jan 31, 2007 1:32 AM by Nickname_is_none
    3D movement and collision queries
    Nickname_is_none Level 1
      I have a 3D box that I want to move a camera around the inside of, using mousedown on sprites. I want the camera to pan left/right, pan up/down, and move in/out (to replicate a zoom).
      I have a bit of script where I set up the 3D environment, and below is the code that I have attached to the 3D member, which is triggered by a left button clicks on each sprite. I've mixed the lingo together from different bits of scripts. The camera pans left/right/up/down, but it doesn't 'dolly' in/out. Can someone show me where I'm going wrong?
      property pGroupName
      property pPanAmount
      property pDollyAmount
      property pAlerted
      property pCamera
      property pCameraOriginTransform
      property pCenter
      property pInitialized
      property pMember
      property pMemberStateOK
      property pQueuedTriggeredEvents
      property pRect
      property pSprite
      property p3dMember
      property pCameraSphere
      on beginSprite(me)
      p3dMember = sprite(me.spriteNum).member
      pSprite = sprite(me.spriteNum)
      pMember = pSprite.member
      pMemberStateOK = me.isMemberStateOK()
      pCamera = pSprite.camera
      if pMemberStateOK then
      pInitialized = me.initialize()
      else
      pInitialized = FALSE
      end if
      pAlerted = FALSE
      camSphereRes = p3dMember.newModelResource("camSphereRes",#sphere)
      camSphereRes.radius = 20
      pCameraSphere = p3dMember.newModel("cameraSphere",camSphereRes)
      pCamera.addChild(pCameraSphere,#preserveParent)
      p3dMember.registerForEvent(#timeMS,#controlCamera,me,2000,50,0)
      end beginSprite
      on endSprite(me)
      if pInitialized then
      pCamera.transform = pCameraOriginTransform
      end if
      end endSprite
      on enterFrame(me)
      if pQueuedTriggeredEvents.count > 0 then
      repeat with j = 1 to pQueuedTriggeredEvents.count
      tEvent = pQueuedTriggeredEvents[j]
      case tEvent of
      #panCameraUp:
      me.panCamera(pPanAmount, 0, 0)
      #panCameraDown:
      me.panCamera(-pPanAmount, 0, 0)
      #panCameraLeft:
      me.panCamera(0,pPanAmount, 0)
      #panCameraRight:
      me.panCamera(0,-pPanAmount, 0)
      #dollyCameraIn:
      me.dollyCamera(0,0,-pDollyAmount)
      #dollyCameraOut:
      me.dollyCamera(0,0,pDollyAmount)
      end case
      end repeat
      pQueuedTriggeredEvents = []
      end if
      else
      end if
      else
      end if
      end enterFrame
      on registerEvent(me, aEvent, aTriggerSpriteNum, aTargetBehaviorInstance)
      if me = aTargetBehaviorInstance then
      tHandler = [#panCameraUp: "Pan Camera Up",\
      #panCameraDown: "Pan Camera Down",\
      #panCameraLeft: "Pan Camera Left",\
      #panCameraRight: "Pan Camera Right",\
      #dollyCameraIn: "Move Camera In",\
      #dollyCameraOut: "Move Camera Out"].getOne(aEvent)
      if symbolP(tHandler) then
      pQueuedTriggeredEvents.add(tHandler)
      end if
      end if
      end if
      end registerEvent
      on withGroupNameOf(me, aName, aList)
      if aName = pGroupName then
      if voidP(aList.getAProp(me.spriteNum)) then
      tNewList = [:]
      tNewList.addProp(me.getScriptName(),me)
      aList.addProp(me.spriteNum, tNewList)
      else
      tBehaviorName = me.getScriptName()
      tSpriteBehaviorList = aList.getProp(me.spriteNum)
      if voidP(tSpriteBehaviorList.getAProp(tBehaviorName)) then
      tSpriteBehaviorList.addProp(me.getScriptName(),me)
      else
      nothing
      end if
      end if
      end if
      end withGroupNameOf
      on controlCamera me
      collisionList = p3dMember.modelsUnderRay(pCamera.worldPosition,\
      -pCamera.transform.xAxis,#detailed)
      if (collisionList.count) then
      me.checkForCollision(collisionList[1])
      end if
      end if
      -pCamera.transform.zAxis,#detailed)
      end if
      end if
      end
      on checkForCollision me, thisData
      dist = thisData.distance
      if (dist < pCameraSphere.resource.radius) then
      diff = pCameraSphere.resource.radius - dist
      tVector = thisData.isectNormal * diff
      pCamera.translate(tVector,#world)
      end if
      end
      on initialize(me)
      pCameraOriginTransform = duplicate(pCamera.transform)
      pRect = pSprite.rect
      pCenter = point(pRect.left + (pRect.width / 2.0), pRect.top + (pRect.height / 2.0))
      return(TRUE)
      end initialize
      on isMemberStateOK(me)
      tOKstate = FALSE
      case pMember.type of
      #shockwave3d:
      if pMember.state >= 2 then
      tOKstate = TRUE
      end if
      #text:
      if pMember.displayMode = #mode3D then
      tOKstate = TRUE
      end if
      else
      if NOT(pAlerted) then
      me.textTypeAlert()
      pAlerted = TRUE
      end if
      end if
      end case
      return(tOKstate)
      end isMemberStateOK
      on panCamera(me, aX, aY, aZ)
      pCamera.rotate(aX, aY, aZ)
      end panCamera
      on dollyCamera(me, aDollyAmount)
      pCamera.translate(0,0, aDollyAmount)
      end dollyCamera
      on textTypeAlert(me)
      tString1 = "The behavior indicated below requires that its text member's display be set to 3D Mode. " & \
      "This sprite's member is not set that way. " & \
      "Please correct this." & RETURN & RETURN
      tString2= "Sprite" & ":" && string(me.spriteNum) & RETURN & RETURN
      tString3 = "Behavior" & ":" && QUOTE & me.getScriptName() & QUOTE
      alert(me.typeset(tString1 & tString2 & tString3))
      end textTypeAlert
      on isOKtoAttach(aScript, aSpriteType, aSpriteNum)
      case aSpriteType of
      #Graphic:
      case sprite(aSpriteNum).member.type of
      #shockwave3d:
      return(TRUE)
      #text:
      if sprite(aSpriteNum).member.displayMode = #mode3D then
      return(TRUE)
      end if
      end case
      #script:
      return(FALSE)
      end case
      end isOKtoAttach
      on getPropertyDescriptionList(aScript)
      if the currentSpriteNum > 0 then
      tGPDList = [:]
      if aScript.is3D(sprite(the currentSpriteNum).member) then
      tGPDList[#pPanAmount] = \
      [#comment:"Degrees to pan per frame",\
      #format: #integer,\
      #default: 2]
      tGPDList[#pDollyAmount] = \
      [#comment:"Amount to dolly per frame",\
      #format:#float,\
      #default: 5.0]
      tGPDList[#pGroupName] = \
      [#comment:"Which group does this behavior belong to?",\
      #format: #string,\
      #default: "Unassigned!" ]
      end if
      return(tGPDList)
      end if
      end getPropertyDescriptionList
      on getScriptName(me)
      tScriptName = string(me.script)
      tName = EMPTY
      repeat with tWord = 2 to tScriptName.word.count
      tName = tName && tScriptName.word[tWord]
      end repeat
      tName = tName.char[3..(tName.char.count) - 2]
      return(tName)
      end getScriptName
      on is3D(me, aMember)
      tIs3D = FALSE
      case aMember.type of
      #shockwave3d:
      tIs3D = TRUE
      #text:
      if aMember.displayMode = #mode3D then
      tIs3D = TRUE
      end if
      end case
      return(tIs3D)
      end is3D
      on typeSet(aScript, aString)
      tCharLimit = 50
      tTempChunk = aString.char[1..tCharLimit]
      tNewString = EMPTY
      repeat while tTempChunk <> EMPTY
      tCount = tTempChunk.char.count
      if tTempChunk.char[tCharLimit] = " " then
      tStopWord = tTempChunk.word.count
      else if aString.char[tCharLimit + 1] = " " then
      else if tTempChunk.char.count < tCharLimit then
      else
      tStopWord = tTempChunk.word.count - 1
      end if
      tTempChunk = aString.word[1..tStopWord]
      tNewString = tNewString & RETURN & tTempChunk
      delete aString.word[1..tStopWord]
      end repeat
      return(tNewString)
      end typeSet
      --beginInterfaceBlock
      --publicHandler = [#panCameraUp: "Pan Camera Up"]
      --publicHandler = [#panCameraDown: "Pan Camera Down"]
      --publicHandler = [#panCameraLeft: "Pan Camera Left"]
      --publicHandler = [#panCameraRight: "Pan Camera Right"]
      --publicHandler = [#dollyCameraIn: "Move Camera In"]
      --publicHandler = [#dollyCameraOut: "Move Camera Out"]
      --respondsTo = [#mouse, #key]
      --respondToOnlyThisSprite = [FALSE]
      --endInterfaceBlock
