7 Replies Latest reply on Mar 26, 2015 11:52 PM by ThinkingThings
    illustrator selecting layers by name then "make mask" command
    Nems77
      Hi guys,
      I'm trying to get a vbscript to do this maybe easy task for some of you
      I want to select 2 layers by name and then set the command :
      NameA = "nomdeCalqueA"
      NameB = "nomdeCalqueB"
      Set appRef = CreateObject("Illustrator.Application")
              Set idoc = appRef.ActiveDocument
              appRef.activeDocument.Selection = Empty
          For Each targetDocument In appRef.Documents
              countOfLayers = targetDocument.Layers.Count
              For layerIndex = countOfLayers To 1 Step -1
                  Set targetLayer = targetDocument.Layers(layerIndex)
                      layerName = targetLayer.Name
                          If (InStr(layerName, NameA) = 1) Then
                          'then select my layer
                          End If
                          If (InStr(layerName, NameB) = 1) Then
                          End If
      Next
      Next
              appRef.executeMenuCommand ("makeMask")
      I'm a little lost...
      Thank you for helping.
      Nems.
        • 1. Re: illustrator selecting layers by name then "make mask" command
          Qwertyfly... Level 4
          the makeMask menu command makes a Clipping mask.
          are you trying to create a clipping mask or a transparency mask?
          • 2. Re: illustrator selecting layers by name then "make mask" command
            Nems77 Level 1
            I'm trying to make a clipping mask, that's why 2 layers is need to be selected.
            I didn't get how to make my two layers as active selections to excecute "makeMask"
            • 3. Re: illustrator selecting layers by name then "make mask" command
              I'm a Javascript kinda guy.
              this will get you started...
              selectAll('cut');
              selectAll('art');
              app.executeMenuCommand('makeMask');
              function selectAll(layerName){
                  stuff = app.activeDocument.layers.getByName(layerName);
                  for(var i = 0; i < stuff.pageItems.length; i++){
                      stuff.pageItems[i].selected = true;
              • 4. Re: illustrator selecting layers by name then "make mask" command
                ThinkingThings Level 2
                I am not aware that you can mask more than two elements, at least not to get the result that I suspect you desire. So what you will need to do, if you have more than one element on one or both layers, is to group the elements, select the two grouped elements, then mask them.
                • 5. Re: illustrator selecting layers by name then "make mask" command
                  TT made me think.
                  if the cut layer has more then 1 item it wont give correct results.
                  make compound path first will help.
                  new script...
                  selectAll('cut');
                  $.sleep(500);
                  app.executeMenuCommand('compoundPath');
                  selectAll('art');
                  $.sleep(500);
                      var stuff = app.activeDocument.layers.getByName(layerName);
                  be aware this will move all items in the 2 layers to the cut layer
                  the sleep just helps reliability...
                  • 6. Re: illustrator selecting layers by name then "make mask" command
                    Nems77 Level 1
                    Hi Guys,
                    thank you for giving answers.
                    My script will be launched on a file with a layer including a path and a layer including a photo, all other layers are hidden.
                    Now I need to translate your javascript in vbscript because it is used in an HTA file.
                    does someone know what could be "layers.getByName(layerName)" in vbscript?
                    thank you again.
                    Nems.
                    • 7. Re: illustrator selecting layers by name then "make mask" command
                      iDoc.Layers("Name") in VB.NET ...  try it for VBS or possibly iDoc.Layers.Item("Name").
                      Again -- just remember you're masking elements, not layers.
                      Since you're more comfortable with VB maybe this could help, albeit it VB.NET. Translation should be pretty easy for you though. Note: I just pop in GUIDs to temporarily name the groups. You can use a different naming convention.
                      Dim aDoc As Document = app.ActiveDocument
                      aDoc.Selection = False
                      Dim grp1 = CreateGroup(aDoc, "Layer 4")   'whatever layer name you want
                      app.ExecuteMenuCommand("compoundPath")
                      Dim grp2 = CreateGroup(aDoc, "Layer 2")   'whatever layer name you want
                      app.ExecuteMenuCommand("makeMask")
                      Private Function CreateGroup(aDoc As Document, layerName As String)
                          Dim tmpGuid = Guid.NewGuid.ToString
                          Dim layer As Layer = aDoc.Layers(layerName)
                          Dim grp = layer.GroupItems.Add : grp.Name = tmpGuid
                          For i = layer.PageItems.Count To 1 Step -1
                              Dim pi = layer.PageItems(i)
                              If Not pi.Name = tmpGuid Then pi.Move(layer.PageItems(tmpGuid), AiElementPlacement.aiPlaceInside)
                          Next
                          layer.PageItems(tmpGuid).Selected = True
                          Return layer.PageItems(tmpGuid)
                      End Function
