1 Reply Latest reply on Mar 26, 2015 6:41 PM by carl type3
    Connection verification failed for data source on port 1433
    ssailer Level 1
      Trying to set up a DSN for a SQL Server database on a new computer and it's failing every time.
      Connection verification failed for data source: csf
      java.sql.SQLNonTransientConnectionException: [Macromedia][SQLServer JDBC Driver]Error establishing socket to host and port: SANDYPC:1433. Reason: Connection refused: connect
      The root cause was that: java.sql.SQLNonTransientConnectionException: [Macromedia][SQLServer JDBC Driver]Error establishing socket to host and port: SANDYPC:1433. Reason: Connection refused: connect
      Now, when I installed CF 11, it installed on port 8500.  However, when I try changing the port in the setup to 8500, I get this error:
      • Connection verification failed for data source: csf
        java.sql.SQLException: Timed out trying to establish connection
        The root cause was that: java.sql.SQLException: Timed out trying to establish connection
      I cannot find anything online on how to fix this!  HELP!!!
