0 Replies Latest reply on Mar 26, 2015 1:10 PM by LR_Mowang
    Sort Preference for filmstrip
    LR_Mowang Level 1
      I know that the filmstrip at the bottom of the display can be sort based on many different parameters. These can be set when in the library mode under the view option. Then you can pop over into develop and it will continue to sort with the settings set in the library mode.  However, if you leave Lightroom and then return, these settings are reset to a default setting.  Is there some way to set the sort parameters permanently to meet a user requirement?
