2 Replies Latest reply on Mar 26, 2015 7:17 PM by Daniel Flavin
    Selectively trapping elements for cmyk output
    roger hodge
      Is it possible to deselect elements (such as a color bar) so they don't trap when printing the page?
        • 1. Re: Selectively trapping elements for cmyk output
          Jeffrey_Smith Most Valuable Participant
          No, Indesign's trapping is based on inks, not objects. You can not select an object and modify a trap on a specific object. Keep in mind, to invoke trapping, you would need to print postscript, as opposed to exporting PDF. When printing ps, you can turn on trap for a composite or separated file using "Application Built-In" or "Adobe In-RIP" trap methods.
          Here's something you can do in Acrobat (depending on how complex the trap and how many times you would need to alter):
          Print composite postscript with trapping on.
          Distill.
          Open in Acrobat.
          Use the Edit Object Tool and select the overprinted objects that make up a trap, and delete them.
          • 2. Re: Selectively trapping elements for cmyk output
            Daniel Flavin Level 4
            As I recall, my .eps color bars are exempt from trapping while my .ai version does trap.
            If the color bar were an image format it would certainly be exempt from trap. (Perhaps a 1200 dpi image.)
