2 Replies Latest reply on Mar 27, 2015 2:52 AM by beh_gras_beh
    Loop problem
    beh_gras_beh
      Dear scripters,
      Is it possible to add XML from character styles in the same text frame?
      I have this but the loop isn't correct.
      #target indesign
      myDoc = app.activeDocument;
      myPageItems = myDoc.allPageItems;
      xmlRoot = myDoc.xmlElements.item("Root");
      createXML();
      function createXML() {
        for(var i=0; i<=myPageItems.length; i++) {
                          var myTextFrame = myPageItems[i];
                          if(myTextFrame instanceof TextFrame){
                                    var myCharacters = myTextFrame.characters;
            for (var j= myCharacters.length - 1; j>=0; j--) {
                                              alert("Item: "+ myPageItems[i] +"\n"
                                                        + "Characters: "+ myCharacters.length +"\n"
                                                        + "CharacterStyle: "+ myCharacters[i].appliedCharacterStyle.name +"\n"
                                                        + "Text: "+ myCharacters[j].contents +"\n"
                                                        + "parent: "+ myCharacters[j].parent +"\n"
                                              myCharacters[j].select();
                                              selection = app.selection[0];
      if(myCharacters[j].appliedCharacterStyle.name == "TAG-01"){ xmlRoot.xmlElements.add({markupTag:"TAG-01", xmlContent:selection}); myCharacters[j].parent.markup( xmlRoot.xmlElements.add({markupTag:"TAG-01"}) );} else if(myCharacters[j].appliedCharacterStyle.name == "TAG-02") xmlRoot.xmlElements.add({markupTag:"TAG-02", xmlContent:selection});
        • 1. Re: Loop problem
          Vamitul Level 4
          You are overcomplicating things quite a bit. just use a simple findGrep:
            app.findGrepPreferences=null;
            app.findGrepPreferences.appliedCharacterStyle="TAG-01";
            var myFound=myDoc.findGrep(true);
            for (var i=0; i<myFound.length;i++){
                markupTag: "TAG-01",
                xmlContent: myFound[i]
            //rinse and repeat fpr "TAG=02"
          • 2. Re: Loop problem
            beh_gras_beh Level 1
            What was I thinking?
            Thanks a million!
