Hosting moved to new server with newer version of CF. Site
was written in CF 4.5.
www.animalhelp.com
Error reads as follows:
Complex object types cannot be converted to simple values.
The expression has requested a variable or an intermediate
expression result as a simple value, however, the result cannot be
converted to a simple value. Simple values are strings, numbers,
boolean values, and date/time values. Queries, arrays, and COM
objects are examples of complex values.
The most likely cause of the error is that you are trying to
use a complex value as a simple one. For example, you might be
trying to use a query variable in a <CFIF> tag. This was
possible in ColdFusion 2.0 but creates an error in later versions.
Have tried everything, can't figure it out!!! Anyone have ANY
ideas I can try?? Attached exact code where page stops and error
comes up. Hopefully it is viewable ok.
