2 Replies Latest reply on Mar 28, 2015 6:02 AM by virginiab603523
    transitions
    virginiab603523
      can you apply same transition to multiple images on different tracks?  (stacked images)
        • 1. Re: transitions
          A.T. Romano Level 7
          virginiab
          What version Premiere Elements and on what computer operating system is it running?
          Generalizing: My answer would be yes to your question
          Assuming Premiere Elements 13/13.1 on Windows 7, 8, or 8.1 64 bit....
          In the Expert workspace, if I have content on more than one track and select the content on the tracks all at one time,
          I can use Timeline Menu/Apply Default Transition to get the placement of the default transition between the pairs on each
          track.
          Please give that a try and let us know if that worked for you.
          Thank you.
          ATR
          • 2. Re: transitions
            virginiab603523 Level 1
            I am using PE 12 on a fully loaded PC, windows 8, 64 bit.
            In Expert workspace, I have stills stacked on 5 to 10 tracks, and have
            resized to make a "collage".  I want to put the same transition on each
            image so as the timeline continues, they all basically transition as one to
            the next image or video clip on the timeline.  I can do this but I have to
            put the transition on each still individually, placing the transition on
            the "left clip".  This works well but would be more efficient if I could
            place all the transitions at the same time.
            I tried setting the transition as default and then Apply Default Transition
            (having selected all the stacked images) but this does not work.  Have also
            tried to place transition on one image and then copy and paste to the rest
            of the images on the stacked tracks. This doesn't work either.
            Thanks!
            Virginia
            On Fri, Mar 27, 2015 at 12:02 PM, A.T. Romano <forums_noreply@adobe.com>
