4 Replies Latest reply on May 21, 2006 8:53 AM by Newsgroup_User
    Frames panel: looping button not working
    Level 7
      I use Fireworks MX 2004
      Frames panel: looping button:
      When I set looping to 2, it stops after 2, as it should.
      All other values, i.e. 1, 3, 4 etc will go on 'forever'.
      What's wrong?
      Thank you for your help.
      Adrian
        • 1. Re: Frames panel: looping button not working
          Level 7
          adrian,
          Could you post the png file online and explain exactly what you are
          trying to achieve?
          alex
          > What's wrong?
          > Adrian
          • 2. Re: Frames panel: looping button not working
            Level 7
            This is just a simple exercise.
            http://www.tudo.co.uk/testing/looping_problem.png
            http://www.tudo.co.uk/testing/looping_problem.gif
            In the png file, Frames panel, bottom left, where I can set looping to
            any number, including 'forever', I set the looping frequency in this
            case to 1. So I expect it to stop after one movement up into the right
            top corner and return to bottom left.
            When I play this in 'original' or in 'preview' in Fireworks, the
            animation moves continuously instead of stopping after one round. That
            is my 'problem'. Or can I not expect this to work while it is still in png?
            When I export it to gif, it works exactly as wanted - once only.
            Adrian
            Alex Mari�o wrote:
            > adrian,
            > trying to achieve?
            > alex
            >> What's wrong?
            >> Adrian
            • 3. Re: Frames panel: looping button not working
              Level 7
              adrian,
              I am not in front of the computer that has FW MX 2004 right now.
              On FW8 no matter what setting I pick when I preview the animation it
              will play forever.
              Once the gif is animated it behaves as expected.
              alex
              > png?
              > Adrian
              • 4. Re: Frames panel: looping button not working
                Level 7
                err... Once the gif is *exported* it behaves as expected ....
                sleep deprivation is showing
                A l e x M a r i � o wrote:
                > adrian,
                > will play forever.
                > alex
                >> right top corner and return to bottom left.
                >> That is my 'problem'. Or can I not expect this to work while it is
                >> still in png?
                >> Adrian
