3 Replies Latest reply on Feb 2, 2007 3:50 PM by WestSide
    Datagrid and "change" event problem, not getting called 2nd time
    WestSide Level 1
      I have a datagrid and I am using the "change" attribute to call a function when an item is clicked in my datagrid. I am using the change attribute because I still want the columns to be sortable via the column header. In any case, it works the first time around, but if I click the same item in the list, it does not run my function again.
      When you click an item in the datagrid I am calling the method "navigateToURL()" and it works first time, but when you click the same item again in the datagrid it does not, I guess it thinks there is no change happening so it does not make the function call. It just sits there.
      Any help appreciated.
      -WestSide
