34 Replies Latest reply on Mar 12, 2007 7:54 AM by hansolo68
    RH6 crashes when generating RH5 project
    BTIMoe
      Hello,
      I am trying out RH6. I have been a RH5 user for the past 2.5 years. I have a huge progect with complex conditional build tags. RH5 works fine when I publish with WebHelp Pro. I am not useing an engine at this time. I was but my project got to big for it. To many pdf files to search on. Anyway. I open RH6, open the RH5 project. I try to generate WebHelp Pro. The files seam to copy OK but when the generating tries to update files. Crash!
      Exception unknown software exception (0xc000000d) occurred in application at location 0x78138890. Any Ideas? I am performing this test on a new computer that has never seen RH5
        • 1. Re: RH6 crashes when generating RH5 project
          Hi BTIMoe
          Okay, color me confused. If you aren't using RoboEngine, why are you publishing WebHelp Pro? Maybe that's the issue? WebHelp Pro only works when published to the RoboEngine.
          Cheers... Rick
          • 2. RH6 crashes when generating RH5 project
            johndaigle Level 4
            Hey, BTIMoe
            What is confusing Rick and I is trying to understand your scenario. When you say "I try to generate WebHelp Pro. The files seam to copy OK but when the generating tries to update files. Crash! " Is this from the "View Result" locally button after generation, or have you tried to publish it to a non-RoboEngine web server and then it crashes?
            I have tried this using the RH 6 Trial version without a problem when I View Results. However you can't publish to a non-RoboEngine because it's looking for the RoboAPI.asp file to redirect it to a virtual directory on the server called "Robo". Why it crashes, I'm not sure. In the past if the RoboEngine was not configured properly you might get a "failed to connect to server" error, but I have never had it actually crash the app. Also, what is the destination to which you are publishing?
            Finally, I know the Trial version has a topic limit (though I'm not sure what the limit is). Could you create a test project of no more than 20 topics and see if that causes a similar problem?
            The bottom line is to choose WebHelp if you are not publishing to a RoboEngine enabled server (or the new RoboHelp Server 6 which replaces the old RoboEngine 4).
            Let us know exactly what your trying to accomplish and we'll take another crack at it.
            john
            • 3. Re: RH6 crashes when generating RH5 project
              BTIMoe Level 1
              I understand your confusion. I was using WebHep Pro to use https: publishing. WebHelp does not support Https:
              I tried using WebHelp only to publish and I got the same error at the same time. so possibly it is the limitation of topics. I was trying it with a project that hat over 2000 topics and well over 2000 baggage files.
              I will try it with a smaller project and let you know.
              • 4. Re: RH6 crashes when generating RH5 project
                hansolo68
                Hello,
                did you find any solution on this topic?
                My wife, working since 5 years with RoboHelp, has the same problem. It seems that the crash only occurs, when using projects that were originally created with X3, then migrated to X5 and now to X6. Projects that were created with X5 seem to work fine.
                The crash only appears, when a "Conditional Build Expression" is entered in the Generate dialog. If you don't evaluate the conditional build tags, it works. But these are necessary. Same applies, when starting the generation from command line.
                Any idea, how to get the old projects working again?
                HanSolo
                • 5. Re: RH6 crashes when generating RH5 project
                  Hi HanSolo and welcome to our community
                  Have you tried the following?
                  1. Close the project, then perform a search and destroy mission. Look for the ProjectName.CPD file and either rename it or delete it.
                  2. Restart RoboHelp HTML and test. When RoboHelp opens the project, it will create a fresh shiny new .CPD file for you.
                  If that fails...
                  1. Compile a .CHM version of the project.
                  2. Perform the steps above.
                  3. Rename the .XPJ file to something different.
                  4. Open RoboHelp and point at the ProjectName.HHP file. A fresh and shiny new .XPJ and .CPD file should result.
                  Let us know how you fare! Rick
                  • 6. Re: RH6 crashes when generating RH5 project
                    hansolo68 Level 1
                    Hi Rick,
                    thanks for the fast reply. Unfortunately it didn't work.
                    For the first option: The database was recreated, and RH6 crashed, when generating.
                    For the second option: RH6 crashed while recreating the database and the project file. But the files were created. After opening that files and trying to generate, RH6 crashed again.
                    We tried to generate .chm and print output. But all leads to the same crash.
                    We have some projects that work fine (these were initially created with X5) and some others that lead to the crash (created with X3, then upgraded to X5).
                    When opening a project of the second class, some files are created (.trv, .trt, .trs, .trl, .trk, .trf and .trb). These aren't created, when opening a project of the first class.
                    I hope you still have some ideas what we could try to get the projects working again.
                    Best regards,
                    Michael
                    • 7. Re: RH6 crashes when generating RH5 project
                      RoboWizard Level 4
                      Hi Michael
                      Have you attempted to examine any of these files with odd extensions to see what they may contain?
                      I'll be trying what you are talking about. Taking a project I create using X3, then opening it using X5 and making an edit, with a final action of attempting to edit using 6. I'll post back if I make any discoveries.
                      Cheers... Rick
                      • 8. Re: RH6 crashes when generating RH5 project
                        RoboWizard Level 4
                        Hi again Michael
                        Sorry, but my tests sailed right along. I took a project that I had created using X3, then opened it using X5. Made some edits. Then I opened the project using 6 and compiled a .CHM as well as generated WebHelp. No crash, no boom.
                        Are you using the full version or a trial? If it's the trial, I'm wondering if this is the reason. If it's the full version, admittedly I'm a bit stumped. If you want, take one of the errant projects, copy it and strip it of anything sensitve, then zip it up and send it to me at this address and I'll be happy to see if I can make heads or tails out of what may be happening.
                        Sincerely... Rick
                        • 9. Re: RH6 crashes when generating RH5 project
                          hansolo68 Level 1
                          Hi Rick,
                          thanks a lot for your efforts. My wife cut down the problem (using several nights) and it seems to be a serious bug in X6.
                          When working with tables (and she has all content in tables) and using merged cells for the last column X6 crashes, when using a conditional build tag. When creating without the build tag, it works.
                          To reproduce, just create a new project and use the attached code for the topic.
                          If you cannot reproduce it that way, I can send you the whole project.
                          Because she is using several build tags in each file and the projects have several thousand files, every hint to fix that problem (automatically) is welcome!
                          Thanks a lot and best regards,
                          Michael
                          • 10. Re: RH6 crashes when generating RH5 project
                            HKabaker Level 2
                            I can confirm that a one-topic project in RH 6 trial version works fine if you don't exclude "print."
                            When you exclude "print," it bombs. I added text and some new conditional build tags. Apply any tag for exclusion or inclusion, and it bombs.
                            Harvey
                            • 11. Re: RH6 crashes when generating RH5 project
                              Michael
                              I suspect Rick is busy on the day job!
                              I just tried your code and sure enough it crashed.
                              I then created a new RH6 project, created a table with four cells, merged two of them, inserted some text and applied the Print condition. On trying to preview that too crashed.
                              Works OK in X5.
                              I'm reporting it as a bug.
                              • 12. Re: RH6 crashes when generating RH5 project
                                hansolo68 Level 1
                                Hello Harvey, hello Peter,
                                thanks a lot for the confirmation and forwarding as bug report to the RoboHelp developers.
                                Here two questions of my wife:
                                Any idea, how to get around this bug, without manually reworking each of about 3000 files (a good global search and replace would be fine)? Or any idea, how long it could take that this bug is fixed and the fix is available?
                                Every help is welcome!
                                Thanks and best regards,
                                Michael
                                • 13. Re: RH6 crashes when generating RH5 project
                                  If for the moment we discount an in-time patch, then either the merged cells have to be removed or the condition. The best multi file find and replace tool I know of is FAR although many swear by BKReplaceEm. Links on my site. Don't start without a good backup.
                                  Looking to the question of a patch, I cannot say but I am pursuing this.
                                  • 14. Re: RH6 crashes when generating RH5 project
                                    HKabaker Level 2
                                    Michael,
                                    Apparently RH is trying to examine the missing cells for x-conditions and can't deal with <td_null>
                                    Have you tried substituting
                                    <td> </td>
                                    or
                                    <td_null></td>
                                    It might damage the table structure, but maybe not..
                                    Harvey
                                    • 15. Re: RH6 crashes when generating RH5 project
                                      Thanks to Harvey for the main part of this solution and a little tweak from me, here's a temporary solution to this problem.
                                      Harvey discovered the problem only occurs if the merge is in the right hand end column of a table. So, add another column and minimise its width, then apply a left border only so that to the end user there is no end column.
                                      Preview and generate that and it works.
                                      Nice work Harvey.
                                      • 16. Re: RH6 crashes when generating RH5 project
                                        UPDATE
                                        It looks like the problem is if the merge is only in the end column.
                                        Also there's a better workaround. Add another column extreme right with no content. Make the column conditional as well. It works and you keep your correct column widths.
                                        • 17. Re: RH6 crashes when generating RH5 project
                                          HKabaker Level 2
                                          Peter,
                                          What an elegant solution!
                                          It's a weird bug.
                                          I would add this to your description of the problem:
                                          It happens only when cells are merged in the final column, and only when cells are vertically merged. In a four-column table I merged the third and fourth columns in just one line; RH took it in stride.
                                          Let's hope this is a temporary workaround.
                                          Harvey
                                          • 18. Re: RH6 crashes when generating RH5 project
                                            hansolo68 Level 1
                                            Hello Peter, hello Harvey,
                                            thanks a lot for your help. My wife tried out, the whole day long, to replace that <td_null>. For a single file it worked, but for the whole project (around 400 replacements were done by the search and replace tool), it didn't help. The project still crashed. What was very strange is that even after replacement, RH showed the <td_null> stuff, but Notepad didn't. Is there a file, where RH caches files? Can we delete that cache to force RH to read each single file? Another annoying problem with that workaround is that RH changes the things back, when opening a file with the WYSIWYG editor.
                                            So, the workaround from Peter sounds very promising. The only thing, we don't know is, how to do such operation in an efficient way (global search and replace). What should be replaced by what? Especially because this affects also nested tables. Where such a merged cell can be in the last column of the inner table.
                                            Any hints on that?
                                            Thanks a lot in advance and best regards,
                                            Michael
                                            • 19. Re: RH6 crashes when generating RH5 project
                                              Forget the difference between Notepad and RH. I've seen that before and it is not relevant here.
                                              You are not going to be able to do a global insert column, at least I don't think you can without a lot of time consuming attempts.
                                              I've just worked with someone to find out which topics are affected and FAR from http://www.helpware.net was perfect to find the topics with tables with merged cells.
                                              I searched on <td_null> and that gave me a nice list in folder order of the affected topics but then you just have to go to each table in those topics and do it manually.
                                              You might be able to configure Macro Express to do that but I suspect you would spend as much time automating the process as getting on with it.
                                              The solution is described in more detail in Snippets on my site. Note it does not affect all tables with merged cells, just those with merged cells only in the end column.
                                              TIP: You might want to keep a safe distance from your wife when you break the news!
                                              • 20. Re: RH6 crashes when generating RH5 project
                                                rwiddick
                                                Hi there
                                                I have the same issue, Robohelp 6 crashes when applying conditional build tags to a Robohelp 5 project AND I am not applying them to merged tables. I applied it to one page at the folder level and TOC level, the page is blank, consisting only a footer with a date in it. When I place the condition in the HTML Layout and compile it crashes every time.
                                                Rebecca
                                                • 21. Re: RH6 crashes when generating RH5 project
                                                  Does that null content topic crash if you preview it with the condition applied?
                                                  Does it still crash in preview if you remove the date as well?
                                                  • 22. Re: RH6 crashes when generating RH5 project
                                                    rwiddick Level 1
                                                    With the footer-preview is fine
                                                    Without the footer on this page-again preview is fine
                                                    I also have an issue with popups (to a picture) (that are in the baggage file) and then linked into a particular size popup, that worked in robohelpx5 and once opened with robohelp 6..... no longer work, they just make clicking noise over and over when you try to use them in a generated file. This is with generation in webhelp but thus far not html help.
                                                    Rebecca
                                                    Thank you
                                                    • 23. Re: RH6 crashes when generating RH5 project
                                                      So that page is not the problem. Somewhere in your help I suspect you have a topic where the two factors do co-exist. It only needs one topic. Use multi file find and replace to search in the code for <td-null>. That will tell you which topics have merged cells and you will need to search through those.
                                                      I don't know about the popups. What OS and browser are you using? Are you viewing locally or from the server?
                                                      • 24. Re: RH6 crashes when generating RH5 project
                                                        HKabaker Level 2
                                                        We've had some discussion previously about conditional tags at the topic level and in-topic application. I think it was during beta test for RH 6. (Oops, was I not supposed to say that?)
                                                        Each seems to work OK independently.
                                                        The problem is when you apply tags at both levels.
                                                        I think it was happening even when the tags were different, and not necessarily attached to the same topic. Don't recall for sure.
                                                        Harvey
                                                        • 25. Re: RH6 crashes when generating RH5 project
                                                          HKabaker Level 2
                                                          By the way, will the next person in this thread please start a new one for topics not pertaining to merged cells in tables?
                                                          Thanks.
                                                          Harvey
                                                          • 26. Re: RH6 crashes when generating RH5 project
                                                            HKabaker Level 2
                                                            Before RH bombs because of the merged cells, it starts to produce WebHelp. You should look in the !SSL! folder to see which topics made it safely ahead of the error.
                                                            The faulty topic is the next one that RH was handling, but may not necessarily be the next one alphabetically in the project folder, or the next one in the TOC.
                                                            At least you'll know about some topics that aren't at fault.
                                                            Harvey
                                                            • 27. Re: RH6 crashes when generating RH5 project
                                                              Potentially Rebecca's problem is related. By viewing the topic she created with nothing in and not getting the crash proved that topic was not the issue, therefore it could be another topic where those conditions do apply.
                                                              I am guessing Rebecca included the second problem in her second post in case there was some kind of link.
                                                              Are you saying another cause of crashing is where two conditions are applied in the way you describe?
                                                              • 28. Re: RH6 crashes when generating RH5 project
        rwiddick Level 1
        Hi there
        I didn't mean to bring a second issue in. The pop up issue does not crash the project so I will start up a new thread for that one...another time. One issue at a time, I have been using Robohelp for about a year so I am just getting pretty comfortable with it, so please forgive that my knowledge is just beyone infancy so to speak.
        I tried the find and replace looking in .htm files for the project folder including subfolders, but it appears that it did not find any instances of td-null? ( I didn't see a way to tell it to look in the code?) I am looking through my charts to see if there is a merged cell in one of them, (I will know because it will give me the option to unmerge??) however, just to be clear, none of the pages with charts have context sensitive tags attached to them. I removed all tags and only tried it on the blank page. I am trying to figure out how to remove the footer but so far no luck. This project was decompiled from a CHM file and recompiled using the ??? tool, not sure if that adds another twist?
        I am using Windows XP professional, 2002 svspack2 with internet explorer
        I am afraid that the wonderful suggestions here may be a bit over my head but I will try to follow along.
        Please let me know if I should start a new thread for this and I will figure out how to do so ....don't want to clog a topic
        Thanks Again
        Rebecca
        • 29. Re: RH6 crashes when generating RH5 project
        I know the popup is not causing the crash but it was possible that there was some relationship. If you are certain that none of the pages with tables have conditional tags, then the cause is something else not related to the problem in this topic. I suspect this thread is going to get long so it might be better to start afresh.
        When you start the new thread, include whether or not a new project with one topic compiles OK.
        • 30. Re: RH6 crashes when generating RH5 project
        HKabaker Level 2
        Um...ahem,
        Actually, the conditional tag does not have to be in the topic with tables.
        Applying the condition when generating WebHelp, no matter where you have conditional tags, makes it fail on the table.
        And, (this is just speculation) even if you didn't apply any tags in any topic, and you include a condition in the build, probably it would fail at the same point.
        If someone wants to test this scenario, fine, but I think we already have plenty of evidence to send this to a correctional facility.
        Harvey
        • 31. Re: RH6 crashes when generating RH5 project
        Thought you had checked what I wrote. :-)
        I'll amend the Snippet.
        From what I was told it is only when the condition is used but I'll check that.
        The bug has already been submitted.
        • 32. Re: RH6 crashes when generating RH5 project
        hansolo68 Level 1
        Hello Peter,
        thanks a lot for your support. My wife managed to get the 38 projects with around 4000 topics working with X6. She told me to say that the workaround with the additional column and the build tag is ingenious.
        While working on the X6 transition she found additional problems (2 leading to a crash and a very ugly one). I open new topics on them. Maybe someone can forward them to the right place to get fixed in the next version.
        Best regards,
        Katrin and Michael
        • 33. Re: RH6 crashes when generating RH5 project
        Don't forget Harvey who found the fact that the crash only occurred if the merged cells are only in the end column. That's what helped me find the workaround.
        Anything you post here does not get sent to Adobe. Do post the other matters as somebody may know about them. This bug is being looked at but you might want to also post the other two here.
        http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
        • 34. Re: RH6 crashes when generating RH5 project
        hansolo68 Level 1
        Hello together,
        Off course many thanks to Harvey and Rick as well, who helped us on this topic, too!
        Best regards,
        Michael
