I have been having issues with my iMac crashing since purchase 12 months ago and after 2 prior clean installs, I'm finally resorting to manually installing all applications after a third clean install.
I have CS5 Design Standard (on disc) as an upgrade from CS2 Premium. I've tried installing CS5 put can't get pass the page where it wants me to put in the serial number for the previous product - it does not offer CS2 as an option in the drop down menu. Only CS3 and up. I have the correct serial numbers registered with Adobe and the CS5 upgrade was bought to work with CS2 and has worked for the last 5 years
Installing CS2 first won't work as it is a Power PC app. I'm downloading a copy of CS5 now in the hope that the install process will be happy with the serial number alone, although I'm guessing it will want me to select the previous product again and will it give me the option to select CS2?
Any ideas would be much appreciated. Thanks. Andrew
I've had to ask Adobe to generate a new serial number that will hopefully bypass the CS2 part.
The serial number is what designates the upgrade status (the software is the same whether the purchase was an upgrade or full) so you are likely to see the request for the preceding version again. I guess you will see if the CS2 option appears or not when you attempt to activate the download.
