2 Replies Latest reply on May 10, 2006 8:13 AM by TimSymons
    about class problem?
    tyrande1982
      class xmlLoad {
      private var xmlName:String;
      public var booleanLoad:Boolean;
      private var xml:XML;
      public function xmlLoad(newXmlName:String) {
      xmlName = newXmlName;
      booleanLoad = false;
      xml = new XML();
      xml.load(xmlName);
      xml.onLoad = function(success:Boolean) {
      if(success){
      booleanLoad=true;
      trace(success);
      }else{
      trace(success);
      public function get booleanL():Boolean {
      return booleanLoad;
      in the code,the sameness name booleanLoad is not one variable;
        • 1. Re: about class problem?
          Peter Lorent Level 2
          Mind the scope.
          var thisObj:xmlLoad=this;
          xml = new XML();
          xml.load(xmlName);
          if(success){
          thisObj.booleanLoad=true;
          trace(success);
          }else{
          trace(success);
          • 2. Re: about class problem?
            TimSymons Level 1
            This is a scoping issue. You will have to do one of the following:
            Method 1:
            Replace this
            if(success){
            booleanLoad=true;
            trace(success);
            }else{
            trace(success);
            with
            var thisClass:xmlLoad = this; // this helps with the scoping by leeting you refer back to this class for inline functions.
            if(success){
            thisClass.booleanLoad=true;
            trace(success);
            }else{
            trace(success);
            Method 2 (I prefer this method): see attached code.
            Hope this helps you out.
