4 Replies Latest reply on Jan 27, 2007 4:42 AM by Coxdabd
    Crossfading Images
    Coxdabd
      Hello there,
      I'm trying to accomplish the effect wherein the image at the top crossfades into the image at the bottom. I've uploaded an example of the effect I want to accomplish - I've left a white line between the two images to indicate the items to be crossfaded. The example can be viewed by clicking here: http://i116.photobucket.com/albums/o20/coxdabd/Example.jpg
      All the best and many thanks in advance,
      Kristopher (UK).
        • 1. Re: Crossfading Images
          Level 7
          I generally think of 'crossfade' as a dynamic thing - open image 1, start
          fading it, see image 2 when the fade is done. If that's what you mean,
          then Flash is probably your best bet.
          If you want a single image, static, no motion, which consists of two or
          more images with less or more transparency in various parts, this
          tutorial might help:
          http://projectseven.com/tutorials/images/p_montage/index.htm
          Joe Makowiec
          http://makowiec.net/
          Email: http://makowiec.net/email.php
          • 2. Re: Crossfading Images
            Level 7
            If I understand you correctly...
            Drag out a rectangle over the area you want to fade and fill it with a white
            (top) black (bottom) linear fill. Select your image and the rectangle >
            Modify > Mask > Group as Mask. That should fade it into the pink background
            colour.
            Peter
            _________________________
            "Coxdabd" <webforumsuser@macromedia.com> wrote in message
            news:epbe4m$gu5$1@forums.macromedia.com...
            | Hello there,
            crossfades
            want to
            | Kristopher (UK).
            • 3. Re: Crossfading Images
              Level 7
              Sorry, that should be linear gradient fill
              "PJR" wrote in message ....
              || Hello there,
              | crossfades
              | want to
              the
              || Kristopher (UK).
              • 4. Re: Crossfading Images
                Coxdabd Level 1
                Hello there,
                Thank you very much for all of your help, advice and guidance. I have no at long last managed to accomplish this effect.
                All the best,
                Kristopher (UK).
