5 Replies Latest reply on Mar 30, 2015 8:28 PM by Johnwhite
    Add empty return at end of story
    Johnwhite Level 1
      Hi experts
      How can make a script for add some empty return at end of sotry, not matter the end is a table without any return?
      Regard
      John
        • 1. Re: Add empty return at end of story
          Loic.Aigon Adobe Community Professional
          You may want to target the last insertionPoint Object of any single Story Object of the document and then fill in the carriage return:
          app.activeDocument.stories.everyItem().insertionPoints[-1].contents = "\r";
          HTH,
          Loic
          http://www.ozalto.com
          • 2. Re: Add empty return at end of story
            hamdifem Level 1
            How can we put the last all paragraph in the story
            • 3. Re: Add empty return at end of story
              Johnwhite Level 1
              Thank you Loic, thank you so much!
              Could you please tell me how to add characters into empty cells.
              for example, I want to add [~8] into every tables' empty cells, how can I do that?
              Regard
              John
              • 4. Re: Add empty return at end of story
                Chinnadk Level 4
                Try this,
                var doc = app.activeDocument;
                var _cells = doc.stories.everyItem().tables.everyItem().cells.everyItem().getElements();
                for(var i =0;i<_cells.length;i++)
                        if(_cells[i].contents == "")
                                _cells[i].contents = "[~8]"
                Regards,
                Chinna
                • 5. Re: Add empty return at end of story
                  Johnwhite Level 1
                  Thank you Chinna
                  thank you so much
                  this script as below function for remove empty column, but in active doc
                  now I only need it work in selection[0]
                  could you please help me change it only work in app.selection[0]?
                  myDoc = app.activeDocument;
                  findTable();
                  function findTable(){
                  for ( s = myDoc.stories.length-1; s >= 0; s-- ){
                    for ( t = myDoc.stories[s].tables.length-1; t >= 0; t-- ){
                     myTable = myDoc.stories[s].tables[t];
                     removeCurrentColumn();
                  function removeCurrentColumn(){
                  for ( i = myTable.columns.length-1; i >= 0; i-- ){
                     if (currentColumnIsEmpty(i) == true){
                     myTable.columns[i].remove();
                  function currentColumnIsEmpty(col){
                      theColumnIsEmpty = true;
                  for ( k = myTable.rows.length-1; k >= 0; k-- ){
                    if (myTable.cells.item(col + ":" + k).texts[0].contents != ""){
                     theColumnIsEmpty = false;
                    return theColumnIsEmpty;
                  function findTableDel(){
                  if (myDoc.stories.everyItem().tables.length > 0) {
                    myAllTables = myDoc.stories.everyItem().tables.everyItem();
                    for ( s = myAllTables.length-1; s >= 0; s-- ){
                     myTable = myAllTables.item[s];
                     removeCurrentColumn(myAllTables[s]);
                  Thank you
                  Regard
                  John
