10 Replies Latest reply on Jan 29, 2007 5:42 PM by forget_r
    ActiveX in Shockwave
    forget_r
      hi,
      I'm have created a director with a activeX control insert. All is working fine til i tried to publish it as a shockwave. The activeX doesn't seems to be copy together with the shockwave itself.
      regards
      Andrew Mak
        • 1. Re: ActiveX in Shockwave
          Level 7
          ActiveX is not shockwave safe, so you can not use ActiveX controls in
          any shockwave movie in a browser. This is for security reasons.
          Imagine the harm you could do if you were allowed to use an ActiveX
          control that deletes people's files for instance.
          • 2. Re: ActiveX in Shockwave
            forget_r Level 1
            Certainly running ActiveX within shockwave can posed a huge threat to all users, but why not give the user a option instead?
            Currently i'm trying to access a database through shockwave and i have found two ways of doing so,
            1) ActiveX control
            2) Using XDK, compile as a Xtra. However i read that you would need to compile them into "safe to use" in shockwave before it can be deploy
            So is there any possible means to access databases through shockwave? thks
            regards
            Andrew Mak
            • 3. Re: ActiveX in Shockwave
              Level 7
              What format/type is the DB you need to communicate with?
              Since you are trying to do this from Shockwave why not use some sort of
              server-side interface language like PHP, asp, ... ?
              • 4. Re: ActiveX in Shockwave
                forget_r Level 1
                Not too sure if i'm getting you, you are saying to use asp(for example) in director itself? if so, is there anywhere i can start off with?
                • 5. Re: ActiveX in Shockwave
                  Level 7
                  No, I'm suggesting running ASP on a/your server and using
                  getNetText()/postNetText() to communicate with ASP pages.
                  Check out: < http://www.shocknet.org.uk/index.asp>
                  • 6. Re: ActiveX in Shockwave
                    forget_r Level 1
                    Oh, sounds like the solution for my headache, i would probably spend some time on shocknet, and hopefully thing works fine,
                    • 7. Re: ActiveX in Shockwave
                      forget_r Level 1
                      hi,
                      i have just finishing reading through the
                      http://www.shocknet.org.uk/defpage.asp?pageID=57
                      However, although it does mention on how to post a query, but i can't seems to find ways to retrieve any result of my query, (in the example above, it does most of the thing except for telling me how to get the result ). i do knows that it gotten do with getNetText() but i really have no idea of how to do that. Anyone can share some pointers?
                      Thanks and regards
                      • 8. Re: ActiveX in Shockwave
                        Level 7
                        Check the docs for getNetText, postNetText and netTextResult
                        • 9. Re: ActiveX in Shockwave
                          Level 7
                          I'd say ask George Bush that question...
                          But, really, server side programming is an option as mentioned but you can
                          also look into the several database Xtras that work over the web. They're
                          pretty convenient.
                          Craig Wollman
                          Lingo Specialist
                          Word of Mouth Productions
                          212-928-9581
                          www.wordofmouthpros.com
                          "forget_r" <webforumsuser@macromedia.com> wrote in message
                          news:epjj54$4bj$1@forums.macromedia.com...
                          > found
                          > 1) ActiveX control
                          > regards
                          > Andrew Mak
                          • 10. Re: ActiveX in Shockwave
                            forget_r Level 1
                            hi,
                            Thanks guys, i finally manage to get the database connection stuff working. Have been going through hell lots of problem as it's my first experiences with Lingo and director. I'm would also apologise for posting without going through the entire shocknet.
                            "hi,
                            Thanks and regards "
