2 Replies Latest reply on Feb 1, 2007 6:04 AM by James Newton, ACP
    Time delay to take screen shot
    AndrewNock Level 1
      Hi all, i'm using the 'ScreenToFile' function to take a screen shot of the screen, but before I use this command, I use a displaySave() to display a place to save the image...
      All good but when the screen takes the photo, it still has the remnense of the 'save dialog box'.
      Any ways to get around this... Thanks!
      --edit - sorry - was meant to put this on the lingo page as more relevant - but so used to being on the 3D section.
        • 1. Re: Time delay to take screen shot
          duckets Level 1
          sounds like you'll need to allow a new frame update to elapse before snapshotting the screen. Can you do this by setting a variable to show that a screenshot should be taken next frame, then unsetting once the shot is taken?
          Alternatively, try adding an 'updateStage' command directly after the displaySave command finishes.
          - Ben
          • 2. Re: Time delay to take screen shot
            James Newton, ACP Level 3
            -- Take Shot --
            -- Parent script
            property pFilePath
            on new(me)
            pFilePath = xtra("fileio").new().displaySave("", "")
            case pFilePath of
            "", VOID:
            return #userCanceled
            end case
            (the actorList).append(me)
            end new
            on stepFrame(me)
            alert \
            "This is where you take your screen shot"&RETURN&\
            "and save it to "&RETURN&QUOTE&pFilePath&QUOTE
            (the actorList).deleteOne(me)
            end stepFrame
            -- In the Message window:
            script("Take Shot").new()
