6 Replies Latest reply on Jan 29, 2007 1:23 AM by Peter Lorent
    Functions and Events
    svinec
      When I type object_mc.onPress = myFunction(param1, param2); on the 1st frame in the Actions layer and test it, the function is called instantaneously and never assigned to the onPress event.
      How can I assign a function with parameters to an event?
        • 1. Re: Functions and Events
          Peter Lorent Level 2
          Basically, you should use a class that extends the MovieClip class and link it to the mc that contains the button. Then use EventDispatcher and dispatch an event, sending an object as a parameter.
          But, a quick solution is using the Delegate Class. See the attached code.
          • 2. Re: Functions and Events
            Level 7
            > 1st
            > instantaneously
            That is correct.
            Its because you are calling the function by having the ( ) after the
            function name.
            You need
            object_mc.onPress = myFunction;
            Jeckyl
            • 3. Re: Functions and Events
              Level 7
              > link it
              > an
              That is overkill for just assigning an onPress
              Jeckyl
              • 4. Re: Functions and Events
                Sure, for just assigning an onPress it is. But the OP wants to pass parameters to his onPress. So, how are you going to do that then?
                • 5. Re: Functions and Events
                  Level 7
                  onPress doesn't have parameters .. so I don't think the OP knows WHAT they
                  wants to do :)
                  maybe they want something along the lines of
                  onPress = function() { myOnPress(param1, param2); }
                  Jeckyl
                  • 6. Re: Functions and Events
                    Sure enough, because onPress is an event. But if you - for whatever dark reason - want to pass data to the callback handler you can use the arguments object as shown using the Delegate Class.
                    But if you want to keep it OO - I doubt that the OP wants that btw - broadcasting a custom event is the way to go.
